Update sky card(FTV)
ettore88
Gibertini 105cm 45E-42E-39E-36E,Gibertini 105cm 33E/31,5E-28,2E-26E/25.5E-23.5E,Gibertini 105cm 19,2E-16E-13E-10E/9E-7E-5E,Gibertini 105cm 15W-12,5W/11W-8W/7W-5W/4W-1W.Decoders:CT HD 5100C/CT2100+
Notebook HP Windows 7 Ultimate
Italy
Hi guys!!!I ask to you a little information about sky card updating(FTV).The update works every day? Or just at night?I know that the update is (usually) Liverpool FCTV channel...In Italy some users have told me that it may take several days!(3-4 days)I do not have a skybox...many users are able to easily update sky card uk ...
I ask you:Day or night to update?How long it takes?What channels?Thanks in advance!!!
There's not a lot to view on the FTV card... just leave it overnight and any channel and it should update.
ettore88
Italy
Hi!!!Thank you very much indeed!!! It is possible during the day?
No idea... it would probably update but most people just leave it overnight.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
If you are reactivating a card my understanding is that it can happen at any time of the choosing of Sky during the 24 hour day, there is no set time
my concern is that you say you do not have a sky box in which case it cannot necessarily happen what box and software are you hoping to update it with?
ettore88
Italy
Many thanks for the clarification!!!My box is Clarke Tech 4100+...
ettore88
Italy
Small curiosity: on average, how long does the update? There is talk of days ...
Retired Mod
www.timo.me.uk
It can take anywhere from hours to days to receive the authorisation, just depends on where in the queue of data your card details are.
Generally people are advised it may take up to 72 hours, but often it's less than that.
But what happens in respect of a Card used in a Clarke-Tech box I could not say.
Retired Mod
www.timo.me.uk
In my Technomate TM6900 Sky cards do not receive the keep alive signal, so need to be put in an official box every month or so for an update. But my software is a few years old now and no longer supported. Many Clarke-Tech boxes are very similar to Technomate boxes.
ettore88
Italy
I put the card in the CT box ...I have tuned on LFCTV.Does not appear "scrambled channel",but only black screen!!It appears you scrambled channel when you're updating?
digi247
NW
see sig
You will need a Linux receiver with Cccam to update entitlements on the FTV card, It wont happen in a Closed source receiver
ettore88
Italy
Hi guys!!!I would ask you...What is a good model of sky box HD UK?
There's only one there now really and that's Amstrad 890/895/595...
ettore88
Italy
Hi!!!I have found this box(sky UK)
SKYBOX VU OPENBOX TECHNOMATE FULL HD
What is your opinion?Thanks in advance!
The Skybox (Formerly Openbox) range are not Sky Boxes ................. they are cheap and cheerful generic receivers which will gain you nothing over your Clarke-Tech.
In fact, the similarity in names has been successfully challenged by Sky and newer Skybox (not Sky Box!) models have been re-branded as Libertview.
As Tivu says those are not Sky UK boxes, And are thus useless to you.
ettore88
Italy
Many thanks for the answers!!!Amstrad,is the only one?
Not Amstrad any longer - they are all Sky branded.
ettore88
Italy
Ok,guys!!!I might recommend you a cheap box?I say cheap because I would use it only to update the card...(Skybox F5s?)
Last question: before I buy the box...i ask you:what is the procedure to update via CCCAM?I ask this because the box clarke tech implements CCCAM.
I apologize if the subject was forbidden!Thanks in advance!!!
