New BBC TP - 11464H 22000 5/6
BlindFaith
TBS 5925
Needless to say it's very strong here....though the VU+ is showing the frequency as 11461H
The frequency depends on the Lnb & tuner match some of my older Lnb's read +/- 2 to 4Hz high,
100 cm dish + 0.2 Inverto Black Ultra
The AZBox read 2Hz low
TM5302HD reads 1Hz low
TM5402HD M3 is spot on 11464 h 22000 This is the correct frequency as per thread title:)
BlindFaith
TBS 5925
This transponder is carrying several BBC Red Button channels now. Both SD and HD, on one currently BBC Three HD is running.
Service 22101 shows a "reed warbler cam live" 2 chicks already have hatched :D
But there a also service 22110 which is scrambled. Could be a HD feed (H.264, 6mbps) Any idea?
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
'2Hz low or 1Hz low'' Guess you mean Khz.:) Sometimes not even a Frequency Synthesizer is that accurate in Hz domain.
Sorry yes =/- 2 to 4 KHz
BlindFaith
TBS 5925
x1000 -> MHz :D
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
BlindFaith
TBS 5925
..service 22110 which is scrambled. Could be a HD feed (H.264, 6mbps) Any idea?
By comparing the clear subtitles I've found the answer: ATM services 22110/22220 show the programme of BBC Three HD. But why is it scrambled??
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
They weren't scrambled last night when I was watching Family Guy, even though they had the $ symbol. Scrambled now.
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
Currently an empty transponder at time of speaking.
This transponder is definitely 2F UK spot.
New test cards on 22110 & 22120 in HD now BCOS Path 2 replaces BBC encrypted channels.
Pietclock
125cm
SE Germany 50°N/11°E
BBC RB1 is now on this TP also via the BSkyB boxes...
Pride Of Cucamonga
Valencia (city)
Huevos, would be really grateful if you could average the signal strength of each transponder across the time you were testing 2E and 2F. Would make a great reference, cheers.
Not quite sure what you mean.
dB or % Quality can only be used as a guide unless you both live in the same location which you do not.
The fingerprint is the same for the whole of this region, just the level changes.
Pride Of Cucamonga
Valencia (city)
I remember you took dB readings of every transponder on 2F, and later 2E, every 10 minutes. I would like to know the average dB of each transponder across the whole testing period. Would serve as a useful reference for knowing which are generally strongest / weakest so i can choose best version of BBC1 etc. many thanks
Transponder changes:-
New Red button info for Tennis & Football
Astra 2F @ 28.2 east 11464 H 22000 fec 5/6
22101 = no pids
22102 = RB-2 test V= 5100 A= 5101 MPEG-2 DVB-S1 in 576i
22103 = RB-3 test V= 5200 A= 5201------------------------------
22104 = RB-4 test V= 5300 A= 5301 ------------------------------
22105 = RB-5 test V= 5500 A= 5501 ------------------------------
22110 = RB HD test V= 5600 A= 5601 MPEG-4 DVB-S1 in 1080i
22120 = RB HD test V= 5600 A= 5601 same pids as 22110 atm this may change,
BBC RB 1= RB-1 V= 5400 A = 5401 in MPEG-2 DVB-S1
This has replaced the previous RB service on 10773 H 22000
