Technomate 5402 M3 Super+
Costactc
Canada
I just received my new Technomate 5402 receiver and it came equipped with the March 5 fw. I was wondering if others have this box and what fw you are using with it.
Mickha
North West
You could try the phantompatch, I think that's the only unofficial support left, for these receivers.
Costactc
Canada
Seems to be d/l ok here.
PM me your email and I'll email it to you.
skomedal
This and that
thule
Have you clicked on the download phantompatch between the 2 white banners?
Regards
Costactc
Canada
Costactc
Canada
Regards
Numerous attempts. I always seem to have issues with these .stb files.
digi247
NW
see sig
The TM5402HD M3 version is just another Clone of the DrHD D15 as is the Technomate F3/5 so any problems related to the D15 are also evident in the M3
Technomate do seem to support there receiver that little bit more than the lack lustre attempt from DrHD
TM also listen (Sometimes to there Owners) when it comes to patched Firmware
Costactc
Canada
I've noticed the similarities. It's menu reminds of the old Coolsat receivers that we used to use.
Costactc
Canada
remlap
Wales
Coolsat and Technomate are related in some way, definitely made by HubTech in Korea.
Costactc
Canada
From what I have seen thus far I'm really liking this receiver and its tuner sensitivity seems to up there with the best. Once I have finished scanning the American c band sats I will be able to determine that.
digi247
NW
see sig
Not sure about Coolsat but Technomate dropped having receivers from Hubtech in Korea after the 5402HD Mark1 version the Mark 2 and 3 and all other newer receivers are now made in china and the price reflects this
remlap
Wales
Ah I have a MK1 so it's still Korean for me.
Costactc
Canada
My favourite dxing receiver I have tested. Tuner sensitivity is excellent and its blind scan is real fast. One issue, as I do post feeds on many sites, I'm wondering if a file has ever been released for the 5402 where video resolution is displayed?
Serafeim
5 dishes, Technomate 5402 M3
Arta, GREECE
The problems begin when you want to watch channels in dvb-s2 8psk with symbol rate <10000...
Costactc
Canada
I'm not quite sure what you mean, I haven't had any issues thus far. I just wanted to know if any previous fw showed video resolution like 1080i or 720p?
pontiend
Contibruter
south yorkshire
I think that Serafeim may have ment below sr1000.
Costactc
Canada
I don't think I've ever knowingly scanned a tp under 1000 sr but thus far haven't encountered any problems.
