hairybadger
Bricoleur
- Jul 20, 2012
- Location
- 46.1N 6.4E
- see sig
- near Geneva, Haute-Savoie, France
I have a Moteck SG-2100 driving a Gibi XP 1m. I'm not convinced it performs particularly well at the extremities of its range; as described in other threads I'm pretty sure that everything is vertical and set correctly and yet I still can't everything that I should be able to. I'm considering replacing the motor with a better model, but I'm not sure if I should jump to an actuator or not. I'm aware that the dish is small and light enough to be driven by a DiSEqC motor. Questions:-
* would there be any advantage in going for an actuator setup?
* what would I need? Polar mount, actuator and positioner?
* if I stay with a DiSEqC motor, any recommendations? Noise isn't an issue - the dish is on a pole at the end of the garden and the cows that are in the adjacent field aren't likely to complain.
thanks again!
thanks again!
