TM 5402HD M3
Just bought one of these and Im having fun setting it up on a cold and rainy afternoon.
First observation though - the initial satellite list is YEARS out of date and manually setting the time and date is clunky. Stepping through the months from Sept 2009 one press at a time isnt clever.......
Assuming the menu is similar to Dr.HD F16:
Set "GMT Usage" to "ON". Then "Local Offset" to "Greenwich", etc.
Costactc
Canada
I find it keeps time and date quite well and looses a minute or two. However, if you have to reboot the box you will have to set it up again. I used the Clark Teck editor for my sat list. I also have one issue as well, when performing a blind scan my 5402 takes up to 20 seconds before it actually starts. Enjoy the new toy, my favourite receiver.
skomedal
This and that
thule
The TM 5402 HD mk1 is reportedly ( according to other forums ) was a superior receiver, this was manufactured in Korea later models in this serie ( TM 5402 HD M 2 &3 ) are manufactured in China.
Sadly am not the owner of the MK1 version:-ohcrap
Regards
Techno m2
Edit rant from another forum:-
And the explanation of Copy TM 5402 it self if you read up is no thing different much the only difference is M1 version done Korea and M2 Version done in China actually what they call better lol. This is really annoying me they never tell truth but always Mislead their own coustmers
Theres something screwy on the lnb wiring / disecq switch somewhere which needs investigating but Im too tired to investigate further tonight.
Sad to say it is all true the best TM5402HD is the M1 version that used to be made in Korea then the contract was awarded to China & the M2 version emerged just as good as the M1 in my opinion,
Then it all changed with the prototype TM_F3/5 followed by the TM5402HD M3 not the same as the M1 & M2 versions totally different build & cheaper parts used,
The software in the M3 & F3/5 has several bugs in it that have not been corrected,
When using normal scan & blind scan the receivers adds transponders that do not exist at these locations,
Eutelsat 9A @ 9 east scan the active part of the ku band here is 11700 to 12500 & the receiver adds more transponders that actually exist @ 9 east,
Scan includes over 80 transponders from 10700 to 12750 only 1/3rd of these are active,
Symbol rates duplicate those on 13 east that I do not receive from 9 east.
42 east is even worse as the M3 adds east transponders that I cannot receive in the UK with a 100cm dish:eek:
Eutelst 16A @ 16 east active part of the ku band 10.7 GHz to 11.7 GHz + 12.5 GHz to 12.75GHz
When I perform a scan on this satellite the receivers add transponders from 11.7 GHz to 12.5 GHz this area is not active in the Ku band @ 16 east,
I have tried the method you mentioned the last time I reported this error s few months back but after several attempts & the progressive upgrades the problem still persists I am not now able to use these receiver for feed hunting due to this fault in the software,
Several other glitches exist with non existent transponders being added to the data base on other satellites consequently I cannot use these receivers to compile accurate channel list as I am able to with the TM6900HD Combo Super+,
I am now using the TM5402HD M3 as a fixed 3x Lnb 28E + 19E + 13E ,
Several months have passed since I made this report to Technomate & still no fix has been forthcoming so I would not recommend this receiver to the serious Feed Hunter on a recent comparison test with the excellent TM5502HD the Blind Scan found 12 transponders between 10950 to 11150 on 10 east using 6MHz steps in the Blind Scan the TM5402HD M3 has a much faster Blind Scan 10950 to 11150 using 4MHz Blind Scan only found 6 transponders as it misses 50% of active transponders :eek: so it is ok for DTH but do not expect much more from the M3.
AS, like others said, use ClarkTech editor. There's also an Excel spreadsheet doing the rounds on various forums, which will create satellite and frequency lists directly from Lyngsat or Flysat sites, based on various parameters you enter. Takes a little bit of setting up but is much easier than doing it all from the remote.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Its a little bit like chicken and egg situation. The Flysat and lyngsat lists are made up by contributers like Wiiliam1 using blind scan receivers. It is in all our interests for there to be accurate blind scan receivers in order that channel lists can be compiled for use by the rest of us.
The tp lists are hopelessly out of date too.
Ive found the old 13E Duna II Autonomia frequency listed (the one with the 3333 symbol rate) - and that closed in 2010!
All the Eurobird 28A -> Astra 2F stuff is missing on 28E too.
Costactc
Canada
I prefer to blind scan with any new receiver. Of course I didn't have any working tp on my 5402 as I set up a whole new sat list. However, when I do purchase a receiver with a working tp list for NA, I delete them all and create my own. I've been using mine exclusively on c band but I switched it over to ku using usals, spot on thus far.
There seems to be a bug in the firmware when editing tp's manually. Its locked up twice in a few minutes directly after a "tp already exists" message, then it loses the info in the frequency bar.....
Not over impressed with it so far to be honest.
^^ The rx is locked solid at this point - only flicking the power swith on the back off & on sorts it
I did have the F15 lock up on me a couple of times over the past few years but never in this screen.
I hope the cable Ive got it connected up to is faulty coz if its not the tuner is appallingly bad. There many 28E frequencies barely registering.
I'll try switching it onto the F3's cabvle tomorrow and see what I can get on there.
Laser
Have had the F3 some months now. Things I can't make out are like. If I delete all the transponders off a satellite and start again.. 23.5 east in question. Next time I go back into the menu they are there again!!!
Basically now I use the F3 for watching and use the Dr HD F15 for scanning etc...
You are right though it does have very old database in it... very old!
My F3 is playing up as well - its started locking up occasionally when changing channels.
So not doing very well with the receivers atm
Vu+Duo - still loath the way its operating system is layed out and it works
F3 - lots of odd quirks, locks up on occasion
5402 - very poor first impressions
The 7020 is still the best of the receivers, but it doesnt do DVB-S2 which is more or less essential so thats a black mark too.
My F3 is like that - rename a channel and rescan and its gets its original name back again. That is bad design.
Damned annoying when you want to differentiate between all the channels called Ch-1 or Tandberg on 21.5E!
Gods some parts of the standard software are just UGLY - the volume muted could have been made a little bit more discreet
AS, you are not moaning about yet another receiver, are you?
sonnetpete
wordpress.com
Normandy, France
Oh how much I've refrained from saying that..........the invite to the G.O.M. club is still open...
