Astra 2E: Central & East Europe Reports
bim
lat 45.3301 lon 14.1822
humax foxsat Thomson Tsr200 Pace 3100 Black pro quad dvbs2 80 and 100cm dishes
croatia Lat 45.3301 Lon 14.1822
Today,30,august,I can Watch all the lost channels ...BBC,ITV,etc...(in SD..no in HD..) What is happening ?
Nothing here east of you and we think a bit up with a 1mtr dish. Please kept us informed.
ralphmagno
naples italy
Hello, I haven't been back here in a while . All BBc,ITV ch 5 and all free view can be received here in naples italy with a 4 meter dish.
Hello Ralph - nice to hear from you.
I want to see pictures of the said dish. Not because it can receive BBC etc. in central Italy but because it's 4m.
Luxlizard
150 cm dish >freesat humax foxsat hd+ I use daily
An old sky.uk pace digibox I use sometimes to watch non-freesat channels
90 cm dish >Pace hd for My Sky Italy
humax combo 9000 (terrestrial and sat)
Bologna-Italy
During the last 2 months I could Watch every day the famous lost channels ..BBC,ITV,Chan 4 etc...from the morning till the afternoon ,..from about 8 o'clock until 5 ,tea time....I live in Bologna,Italy,my dish is 150 cm.....Dear members,what do you think,...with a 180 or a 220 cm dish.. I'll be able to watch those channels 24/24 ?
bim
You have been keeping that quiet. If you are getting them on a 1.5mtr dish it is definately worth a go with a bigger dish. What type of dish and LMB are you using?
Sanca2
4m dish,CoolstreamHD1
N:47.13/E:21.7
Hi
My dish 400cm 2E & 2F 24/24 good signal Eastern Hungary
240cm dish, 2E UK morning and evening good signal, only 10714 morning good,evening no signal
Luniman
Gibertini 125, Opticum quad,Humax Foxsat 1Tb
Lunigiana Tuscany 44.1 10.1
A tricky question Lux, who knows, but I would err on the cautious side and wait till after winter before you spend on a new dish. I would also like to know what the future holds, but looking back a few months, things looked bleak. What interests me is what has changed to bring the signal back to us?
curly wurly
180cm dish - Pace 430N - Inverto Black Ultra LNB
Northern Tuscany, near Viareggio, Italy
I can receive all channels (bbc, itv, ch 4 & 5) 24/7 with clear sky. With heavy cloud I lose most signals in the evening after 7 pm.
Luxlizard
Bologna-Italy
Luxlizard
Bologna-Italy
Mr Bim...My LNB is a twin humax ...the dish is an emmeesse 150 cm made on demand......I was quiet for a few months because I Had 4 heavy operations,months of chemiotherapy,and now radiotherapy.....And the signal was still poor...
In the morning the signal on Astra 2E increases enough that is received with PFA 1.50 m.Must point out that TBS6983 tuner is very sensitive that it receives very weak signal.Although EBS Pro scanned transponders on Astra 2E, the signal cannot be manually lock unless is at least 29% quality.
samoloko
1.8 PFA
EU
2E results that you point out are with 10 dB strength ?
which LNB are you using IBU single moded to PFA ?
how about your Gilbertini 1.50 dish - did you compare gain to 1.5 PFA - winner ?
bim
Samoloko if you don't mind me asking where are you based? I am trying to work out if it is worth me up grading to a larger dish where I'm situated to see if it is fesible
If the signal would have been 10 dB,I would have received all transponders in subband.What is impossible in my area with 1.50 m PFA dish!It is the exact the dish from my Avatar.
I don't know how it is in other parts of Europe, but in my area the signal variation is very high in the morning and during the day.From 5% during the day sometimes reached 29% in the morning between 6:00 and 7:30 EET, and, of course, depends on the weather conditions.Fortunately in the cold(winter) season the signal is stronger and help weak signal reception.
But, in fact, what helped me to receive several transponders was the fact that I used a combination of unusual for a PFA, about which I wrote here ,which for you is not a novelty.
I can assure you that this combination is the best for those who cannot afford to buy very expensive LNB from Noorsat or SMW.And I would say that it is even better than invacom c120 flange lnb!!!I must admit that is a solution of an amateur, but efficiency is well above expectations.Without IBU with scalar rings I wouldn't have been able to receive Astra 2E.
On this occasion, in fact, I checked the sensitivity of the TBS6983 tuner,which is also exceeds expectations .For this reason I have posted on this topic.
Unfortunately about Gilbertini I can't say anything because I haven't tested the signal with such an antenna.
Until proved otherwise, the winner...is my antenna, made of aluminum and brought from Hungary in 1992.I have two such antennas.
samoloko
1.8 PFA
EU
samoloko
1.8 PFA
EU
can you get a stable picture between 6 and 7 30 EET - which transponders, can you post a shot
how much better Is sensitivity of TBS6983 compared to your other card and sat receivers
crazyhania
Famaval 3,10 42 east -30 west
chania, Crete South Greece
Chania Greece I get 24 reception of uk beam with 3 meter famaval. Weakest signal is around 3-4 pm
samoloko
1.8 PFA
EU
can you post some shots with levels
