Tim Bamber
- Oct 25, 2014
- Age
- 53
- 1.8m offset dish, superjack 24in heavy duty motor. VU+Duo2, Smart titanium octo universal LNB
- Malta
Hi everyone,
I'm in the process of setting up the dish in the attached photos.
I bought it second hand and only a few miles from where i live therefore I expected the elevation to be more or less accurate, however, the information I have found on the internet from many different sources tells me that the dish was elevated much higher than it should be.
I have the base set up accurately...
My main goal is to view 27.5W Intelsat but I ideally want to get it setup properly to make use of the motorised capability.
I have calculated the offset angle of the dish to be 24.6 based on the help provided here: -http://www.satsig.net/pointing/finding-dish-offset-angle.htm
and I know that my dish elevation is supposed to be 29.4 based on my location etc from dish pointer.com
What i need to know is as I'm no mathematical genius, if someone would be so kind, is what angle should the face of the dish be? I can accurately measure this angle with the inclinometer on the dish frame shown here..
What I'm not so confident at is using the angle here..
especially when it comes to calculating the declination. Any assistance would be very much appreciated, particularly from anyone who can identify the make or who has a similar dish to this.
Thank you.
Timinuk
Thank you.
Timinuk
