TBS Card 6983
radtv
Supporting Advertiser
For starters TBS will only release official s/w 3rd party s/w will have different options and features. Also the 6983 is a fairly new card and our first stocks are due next week and even we have not played with one, lastly we will ship anywhere European shipping is £15 by Royal Mail Int Signed For.
The TBS technicians will listen to s/w ideas so just email your ideas or needs to support@tbsdtv.com
Using new StreamReader file.dll(test version) and EBSpro 12.0.0.1 (Beta version),MIS transponders can be found with EBS,what before it was impossible.It also can be activated directly TSReader tool or VLC player.
It should be noted that for now EBS has partial support before CrazyCat ensure full support for TBS6983 card.
I did the test at 5W where we have few MIS transponders.
ps_I have to thank again to @CrazyCat and,of course, to @CjCr.
I have a problem with this version satesco.
Won't set to Blindscan2, even though I've set it in Options - Blindscan. Blindscan pop-up when searching a carrier, and we know it doesn't work using that.
Never had that in earlier versions.
Change the two files(.dll & .ini)StreamReader in folder EBS with S.Reader(version test). ini file has log=1,not 5 , as is the old one.
That's the ones I have (pointed to by you in your post) - 17/11/2014 and 18/11/2014.
Not sure what the problem was, but I have it now. Thanks for the update info.
I see what I did earlier - I tried it in BS mode, should have been in DT mode.
bema
Kungsbacka
www.sm6muy.se
TV server: Linux Ubuntu 14.04 LTS
TvHeadend 4.1-1355
TBS6904 (Quad DVB-S/S2)
Dish: TD110, Inverto black ultra quattro
TBS6205 (Quad DVB-T/T2)
Ant: UHF 100 El Triax, dir N
Client: Kodi v14.2 etc
Sweden
Is TBS 6983 more sensitive than TBS 6925 for a "normal" signal e.g. 23Msps/8-PSK ?
@samoloko,
Yes, you can receive MIS-11591 V,Dvb-S2/8PSK at 45E. with TBS693 card.It is also possible to see other transponders MIS of the other satellites with this card:
MIS transponders locked with DVB Dream from:45.0E,13.0E,9.0E,4.9E.
To continue with others MIS transponders from 31.5E and 5.0W
MIS trps from 31.5 E and 7..3 W:
31.5E very difficult to lock here in the UK. I didn't know there was a MIS TP on 7W. I'll check that one out.
There's a new EBSPro update from CjCr - 12.0.0.2.
Not sure if the reported RF Level is correct, seems very low compared to a TBS5925. -68dBm against -59dBm.
Llew, can you point me in the direction of the EBSPro ver 12.0.0.2 please
John, best way to keep up with the many changes to EBSPro versions is to go to the Easy Blindscan Pro section below. The latest version can be downloaded from there.
Need to register though.
http://www.dvbhispano.com/foro/
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
Hi all,
StreamReaderEx-BDA 1.2.2.1248 (Beta)
http://crazycat69.narod.ru/sattelite/StreamReaderEx/test/StreamReaderExEx-BDA.rar
* Full TBS 6983 support with direct hw control STV6120/STV0910ADB
* Ultra-fast and accurate BLScan2() implementation for STV910. Hardware-accelerated edge detection + find unlockable transponders (with poor snr and negative link margin).
* New function ModInv() - detection available frame modcodes for DVB-S2 transponders. Implemented only for STV091x (now only TBS 6983)
* Rewriten CXD2820R support. Extended SingnalInfo2 with specific DVB-T2 params.
For 6983 possible force single mode and double LDPC FEC performance (DemodMode=1 in streamreader.ini). STV6120 is wide-band tuner, so possible extend IF range to 250-2150MHz (IFStart, IFStop in streamreader.ini).
With current 6983 drivers better always use Tuner A, because using B cause driver lockup after close !!!
CrazyScan 1.0.2.112 (Beta)
http://crazycat69.narod.ru/sattelite/StreamReaderEx/test/CrazyScan.rar
* Modcode selection simplified,
* Read available frame modcodes for DVB-S2 transponders in Carrier search dialog (if ModInv() supported)
* Mark unlockable transponders and ACM/VCM.
* User-defined freq ranges selection in Range tab. Predefined ranges defined in ranges.txt file.
* Move some style-specific checkboxes to Style tab.
* Save BLScan2 checkbox state in settings.
http://crazycat69.narod.ru/sattelite/StreamReaderEx/test/CS-New.png
BLScan, BLScan2 1.2.0.1247
http://crazycat69.narod.ru/sattelite/StreamReaderEx/BLScan.rar
http://crazycat69.narod.ru/sattelite/StreamReaderEx/BLScan2.rar
* Show in report unlockable transponder,
StreamReaderExSDK updated (API, BLScan, BLScan2)
http://crazycat69.narod.ru/sattelite/StreamReaderEx/StreamReaderEx-SDK.rar
That's a very handy feature.
Well done - great job as always!
... Thank you CrazyCat, a Christmas present come early.
