Echostar AD3000IP repair required
I'll check it out VS.
U201 in a box with a dud eeprom.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Interesting ...
Here is the internals of my AD3000IP Viaccess..
Curiously a totally different pcb .
U201 is in a different spot ..and is a different device..
but equivalent ?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I wonder which version the OP has ?
Yes, of course. Later version with Viaccess. Same PSU though.
The OP Harper had the non-Viaccess version.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks Llew ..
begs the questions tho'
Are the chips directly interchangeable ?
Are the contents/firmwares the same ?
Which version has the OP got ..as this may be crucial.
this thread started with Harper ..but the eprom issue wasn't him asking ..so
Which version has 'thegoal007' got I wonder..
I'm assuming this is the one currently being asked about.
rgds
VS
Thegoal007 says it's the Viaccess model, so I guess the EEPROM is the same as yours. If that's the case the segment fault in the bad batch of EEPROMS used in the AD3000ip would most likely not apply. So I would think the PSU is the most likely problem (perhaps...)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Liking your logic Llew ..
If psu ..perhaps he could 'have-a-go' his self ..
Don't see why not, just basic tools needed. A visual check of the electrolytics, and a multimeter to check the DC voltage lines out of the PSU (they're printed on the PSU board).
Secondary (DC) side only of the PSU. He must keep well way from the high-voltage primary side. Don't want a funeral this side of Christmas :eek:
thegoal007
echostar ad-3000 ip viaccess
London
I wont be able to pop down and see the receiver until the weekend. From what i have been told he says its now suddenly working, but does occasionally loop around and never starts up and never shows any error on display. I get the feeling he may be looking at getting the unit replaced. He's old (pensioner) and a bit impatient, can't do much until i have a visual inspection on the weekend.
I think they were pretty good receivers back in their day but they are DVB-S only, right?
Tut tut ! DVB-S and Analogue
thegoal007
London
the machine looks like is going into hibernation. He has just signed up and had installed the Greek OTE family pack with new dish and 'their own' box.
