¿So to fine tune you still use sat receptor and monitor?
New to sat meters and just been given the First Strike FS1-SE. ¿Appreciate you set up close to the dish with the meter but does the length of the coaxial from the meter to LNB degrade the meters reading ie: would there be a false/different reading using a 20m length as opposed to a 2m length of cable?
Feliz Pascua.
The Promax MS-250 and S-200 tuner FTE sleep in the closet, and discuss in another post, currently use a gauge Rover SRM-50 (+/- Promax esplorer) I have on loan for years (2008, 1700 € uros then).
The theme of the cable length if you ask in relation to the logitud wave is always important, was 18 when I first cake at a facility 27Mhz. (From 14 manufacturing antennas for friends without problems) measured the cable (RG213 military grade) to avoid problems and removing the stationary meter (SWR / SWR) + 1'5metros extra cable station got into the red zone stationary and somewhat deaf, I added 1.5 meter cable and issue solved.
In our parabolic, which travels down the wire is 950 MHz to 2150MHz, which are 0'315 0'139 meters and meters (wavelength), 1/4 wave is between 7'9cm and 3'5cm.
Out of habit I always use 1.5 meter cable low loss (28dB/100m, I live in 1'13 /1'33millimeters) to measure and cable installation is the same characteristics (motorized / satellite problematic).
For installations with 50cm antenna, one more normal, but good (30dB/100m).
The issue of cable length for lost signal, using this cable (28dB/100m), if you measure 2 meters (-0'56dB.), to then measure 20metros, you would have signal (+/-) 5'6dB less.
Remember that you 0'5dB lost per connector "F" if using pressure adapter connectors, have more losses.
Remember, if you use a switch / DiSEqC 2-4 mouths, will have a minimum 2-3dB lost if 8-16 mouths, and spent a + 5dB to be really as 2 switches in series (EMP-Centauri).
http://www.emp-centauri.cz/index.php?lang=en&page=prodview&id_kateg=1&id_pkateg=21&id=63
http://www.emp-centauri.cz/index.php?lang=en&page=prodview&id_kateg=1&id_pkateg=21&id=284
For powerful satellites that need 50-60cm antennas is no problem, for technical / feed links you can not put these teams.
PS: Thanks, but do not celebrate these holidays.
El Promax MS-250 y el sintonizador FTE S-200 duermen en el armario, como comente en otro post, actualmente uso un medidor Rover SRM-50 (+/- Promax Esplorer) que tengo en prestamo desde hace años (2008, 1700€uros entonces).
El tema de la longitud de cable si preguntas en relacion con la logitud de onda, siempre es importante, tenia 18 años cuando me di la primera torta en una instalacion de 27Mhz.(desde los 14 fabricando antenas para los amigos sin problemas) medido el cable (RG213 calidad militar) para no tener problemas y al quitar el medidor de estacionarias (ROE/SWR) + 1'5metros de cable extra, la emisora se metio en zona roja de estacionarias y algo sorda, añadi 1'5 metros de cable y tema solucionado.
En nuestras parabolicas, lo que baja por el cable es 950Mhz a 2150Mhz, que son 0'315 metros y 0'139 metros (longitud de onda), 1/4 de onda esta entre 7'9cm y 3'5cm.
Por costumbre siempre utilizo 1'5 metros de cable de bajas perdidas (28dB/100metros, vivo de 1'13/1'33 milimetros) para medir y el cable de la instalacion es de las mismas caracteristicas (motorizado/satelites problematicos).
Para instalaciones con antena de 50cm, uno mas normal, pero bueno (30dB/100m).
El tema de la longitud de cable por las perdidas de señal, usando este cable (28dB/100m), si mides con 2metros (-0'56dB.), al medir luego con 20metros, tendrias (+/-) 5'6dB menos de señal.
Recuerda que tienes 0'5dB de perdidas por cada conector "F", si usas conectores de presion con adaptador, tienes mas perdidas.
Recuerda, si usas un conmutador/DiSEqC de 2-4 bocas, tendras como minimo 2-3dB de perdidas, si es de 8-16 bocas, ya pasamos a +5dB al ser realmente como 2 conmutadores en serie (EMP-Centauri).
Para satelites potentes que necesitan antenas de 50-60cm no es problema, para enlaces tecnicos/feed no puedes poner estos equipos.
PD: Gracias, pero no celebro estas fiestas.
