The DirecTV SL3K4NR1-03
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
This is what was sent ..
definately not the same is it..
... interesting VS, i too have this on order..... ordered in good faith that it was the product shown in the advertisement. If mine turns up the same as yours i will put a complaint in to eBay requesting a re-fund as goods were not as advertised and see what happens
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Yes indeed John ..
Do keep me informed..
Ive already sent a message to the vendor about this ..but expect little in response.
we shall see..
Archive-8
If you paid with Paypal/credit debit card. Then you could use the distance selling regulations.
Credit/debit card providers have to comply with it.
As it is clearly not what you ordered its well worth a punt.
Certainly is a distinctive elongated feedhorn shape. Probably used for a particular kind of DirecTV dish?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Indeed it is Llew ..
As it didnt break the bank to buy ..I am of course interested and curious enough to keep it and investigate it's innards ..
Still doesn't fill my need for an unmodded -01 ...
Indeed VS, which was the sole purpose of the purchase .... we'll see what happens.
Good point you made there Chris, we could end up employing it :)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ..since I'm the first to receive my unknown SL3 I figured it might as well be tested ..
..as my bracket on Carl makes for an easy swap with no alignment issues.
Tested without cap fitted and no plates ..thus a combined H and V scan ...
2 nag feeds locked in H ...and managed a partial lock on a newsnet feed at 18558 ..
Gainwise it looks good ..
Here is the scan
rgds
VS
Archive-8
Here is the scan
rgds
VS
What card are you using to test please? Is it your 6925 or 6983?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi Chris ..
Currently using the 6983 ..on account it can handle the higher current demands of my system.
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Being the curious type that I am ..
I had to crack this open didn't I..
lol
Very compact indeed ..
smaller than other versions...and I suspect later design since this one also is mostly surface mount component design.
like other versions except the -o2 ...does not use the 'anex chamber design ' ..so doesn't lend itself to true linear conversion.
That was to be expected ...butI shall investigate this further..
certainly there's no sending it back now..
rgds
VS
Archive-8
Looks like I will have to wait to scan Ka tonight as the USA are flying an F15 over the top of me. And the ber is jumping well above figures the tbs can handle.:-(
Seems there's an exercise going on atm.
That's the same one I received VS, but been busy re-tiling the bathroom fitting new toilets etc.. not even had time to play with mine. She who must be obeyed must be kept sweet to allow me playtime...;)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Is it just me that's getting wild fluctuations on the newsroom feed atm ..
Both dishes ..
Both SL3s ..
Modded -03 and unmodded -03
11 >12 db one minute ..
brief picture breakthrough ...then seconds later ..
zero db ..
I'm frustrated and VERY confused..
That's using the F15 ..
on the TBS card the signal level is fairly constant around 11db ..
No images at all ..
VLC does not run ...and the BER is WILD ..
from zero to 0.8000000+ in seconds ...and everything in between
rgds
VS
Archive-8
Both dishes ..
Both SL3s ..
zero db ..
No images at all ..
rgds
VS
That BER issues is exactly what I was getting with the aircraft above me.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Settled a little topping out around 0.3000000..
brief glimpses of locked signal at this level ..
So pics when BER zero ..and nothing when high ...yet the signal level remains constant-ish.
Solar activity ?
External interference again...
Or simply them pissing about.
bizarre..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Don't think it's the aircraft Chris ..
I think there are instability issues caused by an external source ...either Earthbound or in space
2 constellations and BER rates seconds apart..
Not getting as high as it was 10 minutes ago ..but still enough to prevent any decent lock.
Trust
Nijmegen Netherlands
Both dishes ..
Both SL3s ..
zero db ..
No images at all ..
rgds
VS
here constantly 14.2 dB F16
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Basically I'm back where I was a week or so ago ...when I was blaming 4G..
This is the same scenario ...and I just dont get it.
lol
rgds
VS
An interesting circuit layout VS. A DRO for each KA section. Must've been a reason for that, unless it's a later version of the SL3, and they found it easier to align up each KA circuit separately.
