BBC red button streams back on
Pietclock
125cm
SE Germany 50°N/11°E
well maybe the spot beam rent is higher than PE beam... SES certainly wont switch all TPs to the spot and loose a lot of money...
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Been away for a short while and lots to catch up on but this thread caught my attention........Alicante, nothing received on the 1.2m but on the 1.8m showed 5.6dB, not fine tuned but receivable!
woborny
I an in Gandia 70kms south of Valencia, and the 80x85cm dish is picking them up with 6.5db. The 1.8 marrafa is at 10.5db.
Is there really that big a difference over 100kms that a 1.2m dish cannot receive them and m 80 dish can? I did not think the uk spot beam varied that much.
Retired Mod
www.timo.me.uk
Maybe, but I would have thought that more likely to have been the case when there was a limited supply of spot beams on Astra 2D only but since all the new craft can now do it at 28E I'd have thought it wouldn't be more expensive, but I'm just guessing. Wouldn't it be in SES's interests to eventually persuade more users onto spot beams so that frequency reuse can be used in the future (I'm not suggesting this is the case at the moment)?
One thing I suspect is in our favour is that they need to spread the load over spots and wide beams if they plan to use the satellites to full capacity. There might be a limit to the number of transponders that can use one beam?
skomedal
This and that
thule
Yup
All uk psb TPs on spot beam and the rest ruppies grey zone ( aka sly ) wide beam:D
Thank god for streaming for fringe reception ( ATM watching Demolition BBC2 free )
Central southern norway
Regards
Vitror
Clarke Tech 5100
Czech republik
bbc stream back on 12422 H 27500 2F UK beam,the previous year by about 2 db better:-(,is not now traceable for me:-(, Liberec Czech Republic, Gibertini 125 cm LNB Best HD3D quad Germany
Bengt
1,8m PF dish (situated on balcony),Invacom Quad or Inverto LNB (it varies), Sky Digibox, Humax Foxsat HD receiver, TBS8922 card.
Trelleborg (swedish south coast)
Hi
For me it is the weakest UK spot since the days of 2D.
The higher frequencies are generally the weakest, but when my dish is optimised for 28.5E, I still get 9-10dB on 12129V and 12305H.
I've now re-aligned my dish for 28.2E, which increased 12422H from 2.6 to 3.6dB.
The transponders in bands D & C are 10-12dB, and the other 2F transponders (the 11306's and 11344'S) are 9.5-10.5dB.
So 12422H really is in a class of it's own. I had very good reception last summer. Strange! I wonder what's changed?
Regards,
4wd
Getting the picture
5 W, 9-13-19-28 E
2f uk very weak here, goes away for 6-8 hours in the evening. 12422H the weakest of anything I get from e\f\g
bema
Kungsbacka
www.sm6muy.se
TV server: Linux Ubuntu 14.04 LTS
TvHeadend 4.1-1355
TBS6904 (Quad DVB-S/S2)
Dish: TD110, Inverto black ultra quattro
TBS6205 (Quad DVB-T/T2)
Ant: UHF 100 El Triax, dir N
Client: Kodi v14.2 etc
Sweden
I have a pretty good signal. Like last summer I think.
