M60
Northern England
Could the lower power on the ex-Eutelsat transponders be because it is 36MHz wide instead of 26MHz?
That shouldn't make a difference to the actual carrier level, ie shoulder height. I do know there's different power levels sold to SES's clients, reckon the Eutelsat deal on SES's craft is for the lowest available power to keep costs as close as they were for Eutelsat's uplink operators now compared to E28A.
Tururu
Assembled with recycled parts
Recycled as the owner.
My results, north of Madrid, Spain/Mis resultados, norte de Madrid, España.
Madrid (spain) 22:00 GMT DB800S-HD 29-6-2015.
105 2G E - 11.224H - 16'0dB SNR100% AGC99% BER0 (=)
106 2G E - 11.225V - 16'0dB SNR100% AGC99% BER0 (=)
107 2G E - 11.264H - 17'0dB SNR100% AGC99% BER0 (=)
108 2G E - 11.265V - 17'5dB SNR100% AGC99% BER0 (=)
109 2F RU- 11.306H -  9'0dB SNR 56% AGC99% BER0 (=)
110 2F RU- 11.306V -  9'0dB SNR 56% AGC99% BER0 (=)
111 2F RU- 11.344H -  9'0dB SNR 56% AGC99% BER0 (=)
112 2F RU- 11.344V -  9'5dB SNR 59% AGC99% BER0 (=)
113 2E RU- 11.390H -  8'0dB SNR 50% AGC99% BER0(-2'5dB.)
114 2E RU- 11.390V -  9'0dB SNR 56% AGC99% BER0(-3'0dB.)
115 2E RU- 11.426H -  8'0dB SNR 50% AGC99% BER0 ------
116 2E RU- 11.426V -  9'0dB SNR 56% AGC99% BER0(-1'0dB.)
Madrid (spain) 20:15 GMT VU+DUO2 29-6-2015.
105 2G E - 11.224H - 14'1dB SNR 86% AGC79%
106 2G E - 11.225V - 15'0dB SNR 93% AGC79%
107 2G E - 11.264H - 14'4dB SNR 90% AGC79%
108 2G E - 11.265V - 14'6dB SNR 91% AGC79%
109 2F RU- 11.306H -  9'2dB SNR 57% AGC69%
110 2F RU- 11.306V -  9'3dB SNR 58% AGC69%
111 2F RU- 11.344H -  9'2dB SNR 57% AGC69%
112 2F RU- 11.344V -  9'4dB SNR 58% AGC69%
113 2E RU- 11.390H -  8'8dB SNR 54% AGC69%
114 2E RU- 11.390V -  9'1dB SNR 56% AGC69%
115 2E RU- 11.426H -  8'7dB SNR 53% AGC69%
116 2E RU- 11.426V -  9'1dB SNR 57% AGC69%
PS: Some photos VU + DUO2.
Retired Mod
www.timo.me.uk
Lyngsat has been updated and is showing E28A empty now but they haven't removed the temporary transponders that switched off yesterday. Otherwise it looks reasonably accurate now with the satellite allocations.
Fredrik M
Gibertini 125 dish, Inverto Black Ultra single aimed at 28.2 E, built in Philips TV receiver
Triax 110 aimed at Telstar 12 (15 W)
Landvetter (15 km E of Gothenburg), Sweden
For most transponders, the signal from 2G is similar to what we had from 2F here in southwestern Sweden. However, 11023H (my favorite!) is more difficult to receive than before and compared to e.g. 11097V. I wonder if the skew of 2G could be slightly different from 2F causing interference from the V data transponders to the 11023H? Does anybody have similar experience?
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Here in Vansbro I get nothing on 11023H it was always the worst.
Nalleman
Motala Sweden
Sweden
At my place 2G is a bit stronger than 2F (might be due to the fact my dish is more optimized for 2G).
Some example of values (I will install new software in my receiver shortly showing dB values but for now you'll get SNR %).
2E
(the "old" UK-beam transponders have been a bit lower the last couple of days):
10758 V = 78-81 %
10773 H = 70-74 %
10847 V = 72-76 %
"New" UK
11386 H = 60-65 %
11426 V = 61-66 %
European
11 836 H = 89-91 %
12 480 V = 99 %
2F
"New" UK
11306 V = 57-63 %
11344 V = 59-65 %
11344 H = 55-59%
12422H = 48-56 % (been weaker than before the last couple of days)
European
12207 V = 90-92 %
12545H = 80-83 %
2G (UK-beam was stronger a couple of days ago)
10964 H = 66-70 %
11023 H = 60-66 %
11126 V = 66-71 %
European
All TP:s = 99 %
Generally all UK beams are weakest in the evening (19.00-22.00)
Archive4
11023 is closest to the monster data signal on 11008. This signal will kill all around it if the lnb is even 1 degree out. Skew adjustment may cure this.
Archive4
2E
10758 V = 78-81 %
10773 H = 70-74 %
10847 V = 72-76 %
"New" UK
11386 H = 60-65 %
11426 V = 61-66 %
European
11 836 H = 89-91 %
12 480 V = 99 %
2F
"New" UK
11306 V = 57-63 %
11344 V = 59-65 %
11344 H = 55-59%
European
12207 V = 90-92 %
12545H = 80-83 %
10964 H = 66-70 %
11023 H = 60-66 %
11126 V = 66-71 %
European
All TP:s = 99 %
Can I move in, no Emmerdale
Nalleman
Motala Sweden
Sweden
Fredrik M
Last July I lost 11023, I guess that is when the monster data signal was lit up. I carefully adjusted the skew and managed to regain the 11023 then. I will give it a try to adjust it again.
Fredrik M
Nalleman, here in Gothenburg things seem to be somewhat opposite to where you are: 2F and 2G being the strongest and 2E much weaker. We have fairly strong signal in the evening with a drop at lunch time (particularly on 2E).
Archive4
Skew, Skew, Barney McGrew, Cuthbert, Dibble and Grub!
Tururu
New tp's localized and did not see last night local time 1:00.
Nuevos tp's localizados y no los vi anoche 1:00 hora local.
11081H22000 5/6 DVB-S,VPID 2353. 2349, 2305, 3331, 2310, etc.
11110H 22000 5/6 DVB-S, MTUTV HD, CartoonNetwrk, Boomerang, CNN (Free), CN+1.
Looking, CNN is back/Mirando, CNN, etc es copias de 12520V22000 5/6.
Photos 02/07/2015 11:00 GMT this morning.
Fotos de esta mañana 11:00 GMT 2-7-2015.1_0100.jpg
Ratchet
Falkirk
TM 5402(M2), TBS 6983, Sky+ HD, Stab USALS HH100, Faval 1M, Triax TD54, Hauppauge HD PVR
Falkirk
The output of TPs 65 & 67 is the poorest I've seen yet on 2G. Roughly 1dB lower than 105 & 107 and almost 2dB lower than 103.
Edit: - Sorry, meant to post this in the general dicussion thread.
Mod edit: Moved for you
Tururu
Pietclock, M60 and Solly.
11081 H 22000 5/6 DVB-S,VPID 2353. 2349, 2305, 3331, 2310, etc.
11110 H 22000 5/6 DVB-S, MTUTV HD, CartoonNetwrk, Boomerang, CNN (Free), CN+1.
11552 H 22000 5/6 DVB-S, Capital TV,TV Shop, Record TV, Home Store, etc.
11566 V 22000 5/6 DVB-S, Horse & Count, RT, more>movies, etc.
PD:Buena pesca/Good fishing.
Tururu
I mentioned in the post: Astra 2G: Iberia & Balearics Reports
Lo comente en el post: Astra 2G: Iberia & Balearics Reports
Astra2G movement is affecting small antennas to limit by Madrid (Spain) a partner reports that since 1 day, lost signal 11068V, 11097V and emit Stv 11126v Where hd, hd UTV, ITV and Channel 4 HD.
El movimiento del Astra2G esta afectando a las pequeñas antenas al limite por Madrid (españa) un compañero reporta que desde hace 1 dia, perdio señal en 11068V, 11097V and emit Stv 11126v where hd, hd UTV, ITV and Channel 4 hd.
These channels are moved to the UK beam Astra2G/Estos canales se movieron al Astra2G beam UK el 17-6-2015.
See the circle of Astra2G, not wasted, the second graph allows you to see the variation of the orbital position, each circle is a day.
Mirar el circulo del Astra2G, no tiene desperdicio, la segunda grafica permite ver la variacion de la posicion orbital, cada circulo es un dia.
http://www.satellite-calculations.com/Satellite/satellitemotion.php?26/171/0/40364
Leave a photo, they are updated daily/Dejo una foto, se actualizan diariamente (28.52 <==> 28.24).
Adjusted length values as usual/Ajustada la longitud, valores como siempre.
11067 = 9.50dB Señal/SNR59% AGC99% BER 0 ITV Encore HD (DVB-S2)
11097 = 9.00dB Señal/SNR56% AGC99% BER 0 21000/10/20/30 (ITV HD)(DVB-S2)
11126 = 9.50dB Señal/SNR59% AGC99% BER 1 Channel 4 HD (DVB-S)
Retired Mod
www.timo.me.uk
Hmm interesting, so it looks like 2G is on the move?
popolon
south west of Finland
Teleste 5m,invacom quad (28.2E), invacom quattro (26.0E). Triax multiswitch (1in, 8 out)
-TT 1600 PCI. Prof 3701 PCI.
-DR HD F15
-Ariva ferguson A120
Aerial 3m dish (7W-28.5E) + motor+ invacom quad.
-Ariva ferguson A220.
Finland
But satellitecalculations seems to show wrong 2f/2e/2g future movement. Those cannot be used as evidense, as those predict future, and that has not happened when i have previously checked what this site predict for normal orbit slot, e.g. for 2f .
