Euro (Patio door) lock - how to replace barrel ?
I've lost the key to the patio door which has a euro lock fitting.
The door is in the unlocked state, but this prevents the barrel from being slipped through the door frame and fit the replacement lock.
Is there a knack to this, or do I have to resort to drilling out the tumblers, not something I really want to do.
Thanks in advance
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
The last time I replaced one of these it was necessary to turn the key to a certain angle so that the lock could be withdrawn.
Alternatively, you could try picking the lock. (Not joking, should be possible)
Robbo is correct. You need a key to turn the lock barrel slightly and then you undo the small grub screw holding the barrel into the door. The barrel will then slide out as the tumblers are flush with the barrel.
It certainly is possible to pick locks and a GOOD locksmith can do this. Bad ones will just drill them out.
I hesitate to say this but there are guides to lock picking out there on t'Internet...
Robbo
Retired Mod
Gravesend,Kent,UK
I have picked my OWN front door lock once, just for a laugh, took about 5 mins.
It can be quick if you get it right, or you could be all day trying.:)
As the door can be opened, I have already found and taken out the small grub screw to see if the barrel would slide out, which is when I found the retaining design of the lock.
Damn, I hate drilling locks, metal filings everywhere for cats paws to pick up.
2cvbloke
Near Pontop Pike, Co. Durham
Try sticking an envelope to the door just under the lock and pull it open a bit and it should catch most of the filings... :)
Either that or vacuum up after you're done... :p
gazzz
manhattan plaza 3300 90cm dish
midlands
You can try to make bump key, info here
h**p://uk.youtube.com/watch?v=pwTVBWCijEQ
Masud Ali
Computer with 2Gb ram and dual core processor
Other than replacing or repairing a euro door lock you can alternatively change the lock style from a thumb turn lock to a double key style. This idea can be great for the front door of your house. You can always go to a locksmith to get your lock sets fixed or replaced.
Mod edit: Removed website link
Archived-1
Persona non grata
uk
This thread is 7 years old, it will be fixed by now :).
2cvbloke
I think my envelope dust-catcher idea may have flummoxed him... :-rofl2
Retired Mod
www.timo.me.uk
I did check it and it was clean timo, it was just a link to lock repairs etc.
If he is a genuine satellite enthusiast who has just joined today then I do apologise and hope no offence was caused by my edit, but I was just suspicious of someone who registered today to post a link with a keyword in a 7 year old thread on a non-satellite related subject...
Archived-1
Persona non grata
uk
I just find it easy to check a link and if its not a problem leave it as I did. but nothing is set in stone you made a decision and you have my support, I was just making you aware that the link was checked pal that's all :).
