Archive4
Just switched back to the bent 1.4, no ITV HD at all. All BBC´s CH5 etc ok between 7.8dB and 8.9dB for bbc 1 Wales ( now strongest round here )
Is 11023h on astra 2f, because I get at morning different snr graph related to astra2g 10964/11068/11097? Or what could affect that?
I did wonder if it was a mistake but not sure how the CoB data is generated and not sure why it would be so off occasionally.I just called SES payload management. The very nice pereson on the other end assured me that the data is wrong and will be recalculates regularly. If you look at the top of the page the Window Centre is still 28.2 whereas if you look at 2E COB the Window Centre is 28.5
Yes I was thinking the same, but even with larger dishes it could have been even more tricky as they are more tightly focused with a more narrow beamwidth. At least it looks like it'll just be 0.3° to worry about.That could be nasty if 2g goes to 28.0 at the same time 2e is at 28.5 (earlier post ) it will twice as hard to get both sats on the smaller dishes round here
OK That makes it easy thenYes I was thinking the same, but even with larger dishes it could have been even more tricky as they are more tightly focused with a more narrow beamwidth. At least it looks like it'll just be 0.3° to worry about.
