Archived-1
Persona non grata
- Apr 14, 2007
- uk
The lnb in the photo should have a plate already in it Martin, if it's a LR lnb.
I find it more surprising you getting 12245 H with same strength on circular or normal LNB, than you NOT getting the 12092 R on the circular LNB.I might be getting something now changed lnb type to 10750 12245 is locked in about the same strength as the normal lnb with cloud cover.
Yeah, that's a funny satellite. 12245 is used by both beams, sub-Saharan and Russian, with the former being linear (and usually stronger) and the latter being circular. So you need to concentrate on those frequencies that are used by Russian beam only, else they are fighting over each other (in your location, anyway).I am more confused now Alex its not hard lol 12245 is also Russian beam ?, also didn't you mention to skew and put a credit card in to a circular lnb pal ?
Because the latter I told you would happen!
