36B at 36.0°E
nelson_b
Contributor
hi Evan --
no chance here tonight under these skies:( i only locked 12092 the other day in clear skies -- i lost it when the cloud rolled in ..........12092.jpg
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Cheers Nelson ..
There's hope then ..
lol
Archived-1
Persona non grata
uk
Also no chance here signal is jumping from 28% down to 10% my conditions in picture,
Archived-1
Persona non grata
uk
I will try with a STB ...but no point until the weather clears..
I will set my sat card up in the coming days/weeks it will be interesting what the 1.2 and the 1.8 will see here
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
12129R.png Not much change this morning ..
12129R which was I think my best shot is now hovering around 3.2db with very occasional blips up to 3.5db
The rain has stopped and the dish/lnb are dry ...but it is still cloudy.
I could deduct about 1db for being 2 degrees off focus I guess ..but this would still only give me a possible of 4.2db ..which I think is insufficient ..
So unless there is a time of day element as well ..then Id guess only a bigger dish would make this possible at my location.
rgds
VS
I am flabbergasted that anyone is getting anything at all on Russian beams in the UK.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
It might also be interesting to try an SL3 on this bird ..but not possible for me as there this would require removing all the lnb cluster at the focus ..which is just not worth the effort and would create a lot of work ..
The SL3 wouldn't neccessarily be a good match for our dishes but has the advantage of not using a plate ...due to it's design and use of septum depolarisation..
Anyone wanna try it ?
SL3 VS? Is there any Ka on this bird?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
No Llew but we forget since we generally block it off that SL3 has a ku circular port in the centre ..which covers the same chunk of spectrum we are persuing in this thread..
nelson_b
Contributor
Cheers Nelson ..
lol
hi - just had a look here at 12092 and i,m getting an occasional lock now as the cloud thins
Of course, I forgot that VS. No use my trying with my dish, I'll leave it to the big boys :-lol
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
absolutely nothing here at 12092R Nelson ...not even a hint of NoLocked on the scan ...
out of curiosity ..what do you get from 12130R ?
nelson_b
Contributor
hi - cant tell which beam i,m seeing at 12130 ...... Russian or SSA as i,m just using a black ultra universal l.n.b. ...... 12092 receives the Russian beam on this t.p when set to horizontal --- still locked here now and giving frozen images on NHK world
Archived-1
Persona non grata
uk
I am out metal detecting but I've left my box scanning for the day on 36E it will be interesting to see what I've locked on my return
nelson_b
Contributor
For what its worth on 12130 i get 1.8 db on vertical and 2.7 db on horizontal
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
This is indeed a problem ..
but the reason I'm -assuming- I'm looking at SSA ..is that I'm using a dedicated circular lnb ..and when the L/R scans are combined I dont see a peak for 12130 in H/L
rgds
and at 12092R there is definately more of a hump in the trace in R ..and little if anything in L ..
Still nothing I can analyse tho'
FWIW ...I reckon youd easily seperate and lock 12130R with a circular lnb ..or possibly just a thin plastic plate in the throat of the linear lnb you're using Nelson
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ...still beyond my reach ..but with a 1.8m surely doable..
Took an inverto black ultra and removed the cap ..
Then inserted a long tapered dielectric plate from a scrapped eagle aspen ..
The Aspen onlty covered a small range in the 12 ghz region (DirectTV)
Rotated the inverto through 45 deg ..
This would theoretically reduce any linear reception close to null ..but have no effect on circular ..
Then scanned using universal range in H ..which translates to L ..
12149L is now being received at around 4.1db variable ..
Close but no cigar ..
here is the scan..
Anyone managed this on a 1.5m in the UK yet ??
rgds
VS
Sadly, I can't test 36E on my Gibby as the house is in the way.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
12130R has also increased on this fine evening to about 3.3db ...>>3.9db and fluctuating wildly.
but interestingly ..still no sign of 12092 as locked by Nelson ..??
This peak is simply not there ..
So I am assuming I am indeed ..ultra fringe for the Russian beam ...and only about 70 miles west of Nelson..
rgds
VS
