Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
Also take note of something I mentioned earlier ..I've just put the C back on, if i scan 12092 12244 scans in, also using 10750 lnb setting it wont lock it, 9750/10600 is fine and 10600, certainly getting better results with a normal lnb, i will try a plate in a normal one .
set your linear lnb at 45 degrees when fitting on the dish with plate inserted ..
This gives no preference to H or V ...so as close to null reception for linear as is possible with this type of lnb ..
and therefore favouring circular reception ..to which the lnbs physical orientation makes no odds ..
Only the plates orientation relative to the lnb probes becomes relevant..
At least thats what I found..
