Newbie Here Advice on install
stephen211270
Technomate TM5402 M3
Maxx Digital Satellite Dish 1.1m
NVERTO BLACK ULTRA HIGH GAIN SINGLE LNB
SUPREME DARK MOTOR LED METAL GEAR DiSEqC 1.2 / 1.3 USALS
Liverpool L4
I can input 002.9W wont let me do 2.97W
Put 3.0w then to round it up.
stephen211270
Liverpool L4
have inputed 003.0W
stephen211270
Liverpool L4
thanks Jack and everyone else who has helped all you guys are cool . think I'm almost sorted now just doing a blind scan motor seem to be ok did another reset inputted the information provided still got to do a little fine tuning tomorrow should be all done . I did move it yet again it's not that far off from where Martin suggested I should have listened in the first place but you live and learn. jobs a goodin:)
stephen211270
Liverpool L4
cheers Martin wouldn't have been able to do it without your help and everyone else
stephen211270
Liverpool L4
Hi Guys
I'm back :( right have just changed the wire from my box to dish from Shotgun Cable to a better quality cable as I was thinking that this was the cause of my motor not performing correctly:oops: by not getting enough power to it so turned everything of fitted new wire tuned back on now I get the below message right so again thinking correct me if I'm wrong ? that there is a LNB Fault so changed lnb still get the error have tried testing without motor which by the way shows no signs of life
Archived-1
Persona non grata
uk
Hi Steve give this a go.
a. Press the Main Menu button on the remote
b. Go to Installation > Satellite Setup
c. Check that the LNB Type is Universal and that the LNB Frequency is 9.750/10.600
stephen211270
Liverpool L4
its looking like there is a fault with the new wire somewhere must be a break in it
stephen211270
Liverpool L4
right all sorted . does anyone watch little britain and the fella says I'm the only G*y in the village well Im the only f***ing Idiot in this village:-doh
stephen211270
Liverpool L4
now don't p*s your head off laughing because I know you will. there was one piece of copper wire touching the middle piece of wire on the connection :-lol
TJExcalibur
Out of this world.
Southern England
stephen211270
Liverpool L4
TJExcalibur
Out of this world.
Southern England
:-celebrate:-celebrate:-celebrate:-celebrate:-celebrate:-celebrate:-celebrate:-celebrate:-celebrate
Archived-1
Persona non grata
uk
Easy done and you found it quick well done :).
stephen211270
Liverpool L4
thank Martin first time I have done it as the old saying goes there is always a first time :)
Archived-1
Persona non grata
uk
I bought a little tester, I did it with a ham radio wire last year, and it cost me £40 to have it fixed, I like to do my own installs but I am scared of going on the roof, I paid a tv Arial man to install it and did the wire myself, I had to have him back my own fault,
If you've never made a mistake you've never made nothing :)
stephen211270
Liverpool L4
to true mate .I must be getting to that age now my brain sells are going think I'm left with ten if i'm lucky lol
