Help Required Looking for data sheet of Kathrein (satAn) 180cm prime focus dish
BM300
Dreambox 7000, 7020, 800HD
HD-USB
8 Dishes
UAE
Hello friends,
Can someone help please with a data sheet of Kathrein (SatAn) 180cm prime focus dish?
Thanks.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Nice dish. Made of aluminum. Original polar-mount is one of the best polar-mounts ever made. The rest you can measure. :rolleyes:
Add: I have small sister of it (only 120cm)
I thought Kathrein made a 1.2 and 2.2/2.3 in prime focus, the 1.8 offered was an offset design (CAS 180).
The 1.8 prime focus may have been a Precision reflector bolted onto their excellent 2.2 polarmount which was on par with the IRTE design of the same era.
samoloko
1.8 PFA
EU
where we can see that original polar mount
RimaNTSS
N-E from Riga
I do not know about 1,8m, but, hoping it is same (just little bit bigger) I could provide some pictures of 1,2m polar-mount.
RimaNTSS
N-E from Riga
Found some pictures of SatAn 120. There were also actuator with optical sensor well attached. One U-bolt was missing, so I made it out ot threaded rod. Great antenna, great mount.
BM300
HD-USB
8 Dishes
UAE
Thanks my friends for all the information.
The one I have has a mount similar to this image:
RimaNTSS
N-E from Riga
Az/El mount, not bad, but it will take time to go from sat to sat. :rolleyes:
BM300
HD-USB
8 Dishes
UAE
It is used as a fixed dish pointing at 16East
BM300
HD-USB
8 Dishes
UAE
Hi BM, that mount is very similar to my precision 1.5 mount is now in storage, what information do you need to know please ?
1.5 Precision dish install
Thanks martin-f,
Any technical information please as I have miplaced the dish specs.
If my calculation is right,
Dish depth = 27 cm
Diameter = 180cm
F= 75 cm?
F/D= 0.42
Just wanted to confirm my finding.
Archived-1
Persona non grata
uk
Thanks martin-f,
Dish depth = 27 cm
Diameter = 180cm
F= 75 cm?
F/D= 0.42
Rimants, will be able to help you:), I did read you had to be particular with the feed horn used with this dish.
BM300
HD-USB
8 Dishes
UAE
Thanks my friend.
Archived-1
Persona non grata
uk
Theirs a video of this dish here, I think the mount that Rimants is referring too can be seen about 5.30 mins in.
RimaNTSS
N-E from Riga
Dish depth = 27 cm
Diameter = 180cm
F= 75 cm?
F/D= 0.42
Your calculations are perfectly right.
BM300
HD-USB
8 Dishes
UAE
Thanks RimaNTSS.
