Opening NTV-Plus HD Card with DM8000 HD using Newcs Server
it work also dm 7080 an dm 820 /.
Oopnt
NTV-Plus, DM 8000 HD, NewCS Server
Cyprus
Oh wow! Thank you Solly.
So lucky to have found this forum. You have no idea guys how many forums I had signed up with and this is the best! :-respekt
smoggy07
I already have the ci module, tried it out and nothing. I did called them to Russia and they said the module doesn't match with the zerial number of the dreambox.
I have a feeling the card is paired to the official receiver/CAM using the serial number/boxkey and you'd need the card pairing to a box that can activate the card or you might need to enter a boxkey of a legit receiver into your SoftCAM on the Dreambox to get the channels to clear
I needed to enter the boxkey from my legit subscription receiver into CCCam to clear channels on my DM500s
Can you borrow an officially supported receiver to try and open the channels or activate the card?
A nonymous
I didn't realise they were pairing Viaccess cards or is yours the conax card smoggy.
That may well be the issue here, if the original posters card is Conax and not viacces then it could well be CAS7 paired. If its software paired it should be readable providing the boxkey can be read from the card., if its hardware paired it wont be able to be shared.
smoggy07
Sorry I should have been more clear with my post, it was, at the time, a legit sub that used pairing and boxkeys, I'm not sure if they use pairing on the card the OP has but the part in the first post about a serial number got me thinking this might be the case
Also I quoted Solly but didn't add my question :-doh
@solly how did you get the card working in your Dreambox(s)?
drats
VU+Duo, Vu+Duo2, Vu+Zero, Gibi 1.5m, TBS 6903 PCI
North West UK
If you don't have the boxkey and AES key, it will not work. You will need a paired receiver for a start as info won't be extracted from a cam
Oopnt
Cyprus
Oh !
Well! So, if I find a boxkey of a legit receiver it will work or not?
Oopnt
Cyprus
To be clear again, I am talking about the new HD NTV-plus card.
Ccam can read the card up to a point, for ex that it's viaccess and which is the provider, but it doesn't work.
Of course it's legitimate to have the channels in both of the rooms in my house. I won't be sharing the card channels outside my house!!!!!
I have 2 dreambox, one in the living room and one in the bedroom and I would like to have the channels in both rooms. That is the reason I am asking in the first place.
Fair enough :) - although we still have to be very careful how much help we allow. However its ok so far.
A nonymous
OSCam can read Viaccess 5.0 cards without a problem. If you google "NTV oscam config" you will find the config for it. Due to the constraints of the forum rules we cannot help you with the oscam config although they are easy to find.
If the card shows as clearing but gives a black screen its likely its using AESKey secondary encryption, we cannot help you with that either. It may be worth you looking on the OSCam forum for further help.
Nano
Oopnt
Cyprus
Great guys!
Thank you Nano!!
I do hope I can figure this out or else, not happy wife...lol hahaha
Let us know how you get on - these unusual requests are always interesting. I cant remember the last time we were asked for help with with an NTV problem so it must be going back a bit :)
