Motherboard has died
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I assume you have tried a bios reset as this will revert the bios to its eeprom stored factory defaults
So far I have tried clearing the CMOS using the external dip switch (motherboard feature? and also internal jumper. I have also tried removing the battery, but not for an extended period.
How do I reset the bios other than removing the battery?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
If you have done a dip switch reset then you have reset the bios to factory settings, it does sound like the cmos has failed, to be sure it is worth trying to boot without keyboard and any additional cards in use.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Went to check the CMOS booted without keyboard and any additional cards in use.
Gave same error code as before translating to:
"Complete uGuru inital process, AWARD BIOS take over booting job"
Would this be CMOS or BIOS at fault?
Topper
Well based on what you are reporting it would seem to be the bios but I cannot say I am an expert when it comes to cmos/bios problems, I take it you are never achieving an option that allows you to enter the bios to edit the cmos date and time in which case it seems to be the bios
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I appreciate your advice and take onboard you may not be an expert.
That's right nothing displaying at all, no response from input either.
Thinking of ordering the replacement bios chip to see where that gets me. :cool:
Topper
I take it there is a working cmos battery in there, i.e. have you checked the voltage output?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
As far as I know the battery is fine not very old.
Voltage output of?
I don't have a multimeter so I cannot measure anything. o_O
Topper
Voltage output of?
In that case you are not able to measure the battery voltage
battenfan
1.2m pf
60N 18E
I'll say that's a long shot. It's more likely a ram fault. Bios needs ram to boot.
Try pull some of the memory modules and keep a minimum of them in if you can. If there's no difference try moving them around.
Topper
Worth a check but onboard low level check prior to bios takeoever should have produced beeps or flashing light to indicate ram failure
pgh13
Midlands UK
I'd be suspicious of ram. Also, and not wanting to insult your intelligence, make sure that in your troubleshooting you haven't changed something that is further confounding the problem, e.g. leaving the CMOS jumper in the clear position stopping the board from booting. I've seen that a time or two., although you said it was a DIP switch in this case. What board is it?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I will try to check the ram later, although I don't have any replacement to try with so have to test with what I have.
Yes there is a switch on the outside of the case and also a standard jumper type near the data ports, 99% sure these are set correctly.
Motherboard is an Abit IN9 32x-Max
battenfan
1.2m pf
60N 18E
Reading Abit site it seems this motherboard might run on dimms installed in slot 1 & 3 (depending on what dimms they are). The reason I don't think it's the bios chip is that it froze while being in use. The bios usually gets copied to ram at boot an never used again until next boot.
Luke61
80cm Technomate, Philips twin lnb, Telekom HD receiver, fixed on 39E
Leicester
try disconnecting everything from the system board except: cpu, graphics card, 1 memory dimm, power leads. see what error you get.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Checked and the dip switch and jumper are in the correct "normal" non clearing position.
I have been using the RAM in slots 1&2 as the manual where I'm looking does not state that they needed to be in 1 and 3. Been using it like this for years, I wonder if its affected it.
Done this but same error even switching the 2 RAM modules I have been using with each other in slot 1 but still the same.
battenfan
1.2m pf
60N 18E
No, if it has worked then fine. I was wrong. I was referring to this:
http://abit.ws/test-report/in9-32x-max-wi-fi.htm@2
I thought, if you had 4 dimms you could pull 2 of them out.
"To reach optimum performance..." sounds as if it might run on a single dimm.
http://www.manualslib.com/manual/205151/Abit-In9-32x.html?page=18#manual
pgh13
Midlands UK
Clutching at straws, i know..... spotted this in answer to a similar prob with an AN8 board
The remote CMOS lead is an issue - removed it and used normal jumper after doing a clear and it booted.
Put it back the other way round (there are only two ways it can go) - no go.
Remove it and clear CMOS and put the normal jumper on and it RUNS.'
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Just used a standard jumper on the CCMOS1 located under the SATA ports but no difference made, same error code.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
So guys the only thing left to try is switching the BIOS chip?
I think thats probably your best bet now.
