51.5E Belintersat 1
Test carriers on 11415 V & 11455 V
Test carrier 11590 H
tempo
47.5N, 42.2E / Russia
26 January:
11380V (many times repeated)
27 January:
11415V
~11230H
11053V (few minutes ago)
27 Jan: 11420 V, 11230 H (high power) and 10972 V, 11052 V (low power)
New test carrier @ 51.5 east
Belintersat 1 (Belarus Sat 1) @ 51.5° East
Test Carrier 11210 H
satkingdom
Turkey
10 fixed offset antennas ranging from 107 cm to 170 cm with multifeed systems on them.
Next Machina3D Satellite Receiver
North-East of Turkey
Activated carrier frequency 11210 H 6827 3/4 DVB-S2/8PSK
@satkingdom, those are preliminary data that may change during the satellite building.
This 11210 H is 19.5 dB here, indeed it comes from 51.5°E.
But how can Belintersat have 11.2...11.45 GHz transponders, if TurkmenAlem at 52.0°E also has these, with overlapping footprints? They will have to coordinate the use of this band.
Is 11210H still on? Not seeing anything here, although the 52/53E dish may be a gnats whisker too far east.
11210 H has been turned off...
Damn :D
Ive split the reception reports off the launch thread & moved them into Fringe Reception.
10972 H 30000 2/3 DVB-S2 8PSK possible new data stream or test carrier from 51.5 east or 50 east very strong signals here on my 88cm set up.
Just having another blind scan as there are 3 satellites in close proximity 52 east,51.5 east & 50 east the 1st 2 cover 10.7 to 10.95 & the last 2 cover 10.95 to 11200 also picking up 53 east on 52 east satellite so it is a job to find out which has the strongest signal for each transponder so as to determine what satellite it is coming from :eek:
puteez
Octagon SF4008- 90e-0.8w
Ukraine
3557, L, 1603, 5/6, DVB S/QPSK,|Data,
3685 ,L, 15280, 3/4, DVB S2/ 8PSK, MPEG- 4 T2- MI
3715, R, 14990, 3/4, DVB S2/ 8PSK, MPEG- 4 T2- MI
3806, L, 13270, 3/4,DVB S/QPSK |Data
3550 L 3550 5/6, DVB S/ QPSK
Anonymous_1
very similar to 53°E...
I can't check it by myself right now, but I think it's 53°E instead of 51.5°E, am I wrong ?
puteez
Ukraine
You're right , sorry
pontiend
Contibruter
south yorkshire
All I see on this satellite is the test carrier at.
11445H
TBS6983 100cm Dish
