Advice Needed Technomate TM-5402HD C1+ Super +
Spiff
Mullion Cove Cornwall
shopingathome.com
Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
Good evening gentlemen.
In the menu there are these options.
Please see attached images.
Are they encoding ?
If I enable them will some of the channels which do not have a $ type sign that are live, but show no sound or vision, be enabled ?
Thank you Spiff
Anything that does not have a $ sign is either not scrambled or isnt running at the current time. Its possible its just a dead label from a tp move, or its just off air.
If you put the latest patch onto it (via Entertainment - TM Online) you will get some of the scrambled channels opening - the Swiss HD channels on 13E, some of the BISS stuff around the arc plus a few more interesting ones which I'll leave you to find out ;)
Eusebius Punz
Oberndorf, Lower Austria
Wavefrontier 30" W - 28,2" E
Oberndorf
This Options are back when the goldwafer, etc. make good work. AU stand for Auto Update. But do not work now.
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Hallo I have done a lot of searching but not sure where to look for the patch ?
Regards Spiff
Mickha
North West
Try an internet search for latest phantompatch 5402.
