- Location
- North Nottinghamshire.
Strung it last night and it was pretty close. Aligning the holes and the petal levels must have helped. Spare scalar - good idea, thanks.
2.4m at C band is about the same as 90cm at Ku on the woolyness scale.
I'll try but work gets in the way
That confuses me even more. I find it hard to believe that the footprint varies as much as it appears. The strongest TP for me was 3984V at 9.3dB SNR.
7 transponders on 40E locked whilst pointing at 38E.
I can't find the beacons on 38E 3702.9H & 4196.5H according to http://frequencyplansatellites.altervista.org/Beacon-Telemetry_Europe-Africa-MiddleEast.html . 40E beacons are strong.
I'll check out the 38E beacons shortly G, we are very heavily covered in a thick layer of frost & mist at the moment .... Brrrrrrrr very cold this morning.
