21.5E (Eutelsat 21B)
fidelis
Offset 115cm, Openbox SX6 HD CI+, Openbox S3 HD Mini
North-East of Poland
11620 V is/was Skylogic (Internet service)
gafsa
180 c/ku band
tunisia
12708 H 2104
lc2 international Benin
LC2 has moved to 11107H 2104 3/4 DVBS2 QPSK
Strong signal even on a drizzly evening here
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
Not one I've found but pasting this info from another forum:
10996H 2667 DVB-S2 QPSK - refeed of NBC
Apparently been broadcasting a while now and probably will continue for the duration of the Olympics. An easy catch up here on my 1m dish.
blademedia
Sky
quite sure this ones from here ? ghosting ? 12871/6112/H (mali-benin_)
Laser
The new transponder 10919 Horizontal 33710 3/5 DVBS-2 8PSK
I was wondering in anyone can receive this in Western Europe? Both Flysat and Lyngsat show it on a Widebeam but I would think looking at the channels it is likely on the Eastern Beam.
Other channels which are on Widebeam are no problem to receive.
Was wondering if anyone had any thoughts???:rolleyes:
pontiend
Contibruter
south yorkshire
I receive it here at 54%. sometimes goes to zero and back.
TBS6983 100cm Dish.
Lexzie
TBS 5925 USB-tuner
The Netherlands
According to the frequency plan it cannot be anything else than Wide Beam.
Still I have also no signal, but 8PSK channels are difficult. F.e. I also have no signal on 11006 H.
And at the moment not the best LNB on that dish.
Laser
Hi Lexzie,
Strange I can get 11006 Horizontal with 12db. That's 8PSK as well and Widebeam
aceb
Prof Tuner 7301 /
Sussex
Here's mine on the 1.2m.
Lexzie
TBS 5925 USB-tuner
The Netherlands
Hi Lexzie,
11006H is fine here too 11dB.
I don't know why either. Dish is aligned perfectly (I even checked it this afternoon).
Maybe it's the receiver I use.
This is what I have (TBS5920 on my Xtrend ET10000):
11394 H: 3.9 dB (with high BER)
11488 V: 10.3 dB
11547 V: 10.6 dB
11582 V: 12.0 dB
11585 V: 11.8 dB
11590 V: 9.2 dB
Others none. Also tried 1-2 MHz above and below the frequency.
pontiend
Contibruter
south yorkshire
This is my haul for that range of transponders.I get nothing on.
11582.V 11585 V..
TBS6983 100cm Dish.
pontiend
Contibruter
south yorkshire
Thanks blade got it.
I just entered the transponder into DVBDream It comes in at 84%.
The problem was that my dish has moved a bit.I am always fiddling with the longitude settings.I have 1.2W in dvbdream.1.3 in EBSPro.
I think that that indeed does send the dish 0.1 degree further east when moving the dish with DVBDream.
blademedia
Sky
You have to with fringe :) most satellites have a slight drift that little bit is a lot and dish tweaking is a must :)
I use a positioner with remote control, this way I can tweak without going into any settings
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Here is my BS with my 2.1m. I noticed that the signal during morning hours is around 1-1.2 dB lower than evening.
MCelliotG
Thessaloniki, Greece
10919 comes in my system @ 8.7db right now.
