28.2E sudden loss in Netherlands
colin. said:
I had a guy from the local satellite installers come and check the dish alignment. He pronounced it fine. He checked the co-axial cable and said that was fine, too. And the receiver is also apparently fine. He changed the LNB. After all his checks I was still unable to pick up most of the channels and he said he was unable to help further. Scanning Astra 2A now shows some channels but not all, and not consistently (most notably no variants of BBC1, BBC2, BBC News or Channel 4 HD). The only consistent thing is that signal strength varies from 50% to 100% and signal quality remains at 0%. It would also always (before the problems) pick up all the Sky UK channels (though I'm unable to view them obviously) and now it shows none, perhaps another indication of something wrong. So I'm fifty quid down and I still have no solution. I guess the satellite didn't fall out of the sky a few days ago, did it...? ;)
Correct me if I'm wrong but all BBC variants etc. are on the Astra 2D. Same position of course, but can you scan Astra 2D in the menu? Most FTA channels are on Astra 2D and the Eurobird (only a few on the 2A and B). Channel 4HD is on the new Astra 1N (temporarily at this position).
colin. said:
The *only* channels I now get are: - Mezzo LiveHD - C+ Deport HD - Nat Geo HD - Cinemagic - Calle 13 HD And one radio station, Radio ESP.
FYI Those channels are on 10936 V (19.2 E) and are encrypted. At 28.2 E 10936 V is on the Astra 2D (ITV 1 Granada HD and STV HD).
Is signal quality the quality of the signal passed down the coax from the lnb to the receiver? if it is and it`s showing 0% quality it`s proberbly the coax cable
could you get a small run of coax cable from the lnb to the receiver (if you can bring the receiver and a tv to the dish) and do a scan for new channels, see if you get any, if you do then its a cable problem
in any case if it is a propper Freesat box from the uk when you do a factory reset the box should default to 28E in freesat mode shouldnt it?
