Robbo said:It doesn't look too bad, though if you go above the roofline, you shoukd get a decent part of the arc. Eastwards won't be a problem if you put it below though, I think.
Difficult to tell exactly but 1W looks possible from your proposed position, a survey with an angle meter or a dish would confirm.
Yeah that is what I am thinking - anything above the roofline should ok for all of the arc.
The sats I am interested in are 0.8w and east from there so even if it was just under to roofline it shoudl be ok.
The line showing south is right - it is not totally accurate but it was just to show the general direction of south.
I am hopefully going to try an install it at the weeken with the help of my bro and dad - in other words I will be standing around telling them what to do
Fingers crossed!
Cheers guys
