Another Channel Master SMC 1m20 restoration X2
take some pictures of the main board !
Plan B : build my positionner :lol:
:lol:
winter is coming
I should be ready to start it next month. Without this first motorized antenna it would not have served me much. :)
On my side, I also started to think about my version after yours but I would need your skills to validate certain points and especially to add a DiSEqC part to this : :)
for the disecq: if you want to detect it on the fly you need a microprocessor more powerful than the arduino and work in assembler but there is a solution is to take a small microprocessor on a dedicated card which only recovers the diseqc and supplied on demand by serial link (I made a card like that)
Whoops ! I did it again...
When you go somewhere for her (my wife says it's a disease ...)
and you come back with gifts
So, 2 becomes 3 Channel Master.
This one is a 90cm.
2 and half rotor from Echostar.
one Vbox2
And an Echostar LT 8700 D/D2 Mac
Not to bad for a grey sunday :)
This one is a 90cm.
one Vbox2
i have a spare 90cm CM too - i only wanted motor from it for my 1.2m CM had to drive about 40 miles to get - good fine as long as you didnt pay too much
50 Euro for all and 150 Km this morning.
like you, In fact I wanted the mount, the motor and the L stand.
original matched feedhorn too i see - do they work on 90cm, 120cm and 150cm?
For 90 and 120 it's sure.
For 150 i don't know.
I will open it this afternoon
and 150cm?
What do you mean by 150? There are no Channel Master antennas in that size. CM antennas only available 0.75m, 0.9m, 1m, 1.2m, 1.8m and 2.4m. Original CM feedhorn can work on all of them.
I was afraid to say something stupid, I had never heard of a 150 ...
Maybe he want to said 180 and i have no idea if it's the same feed as the 120.
It's seem to be the same
lol my bad - sorry chaps...
i think it's an MTI like my Philips
For the 90Cm.
After a good cleaning I started the painting with a test on the upper right part with another paint.
More covering but bubbles appeared after 5 minutes ...
At the same time I painted the two feed horns and restored one from that :
To that.
I installed the LNB too early and after one night moisture formed inside.
The cleaning of the interior with hot water is surely the cause ...
Following some advice and the work of @Manikm909 for his project:
Just Sharing This - My Channel Master 1.8 project.
I decided to paint my Channel Masters in matt camouflage green RAL 6031.
I used this color because it's the one used by the armies in Europe.
They had to work hard to decide it was the right one for camouflage, so let's use it !
Thanks, but you gave me the idea. :)
I think it's the same color as yours. the result is as in your photos. I'm pretty happy with the result. :)
Starting the restoration of one of the CM polar mounts.
