Satcom1
- 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver.
Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band.
- Chicago
casser said:I´m still trying to understand how you got that perfect shape..great work!!
After you finish the antenna and test it, can you create a tutorial?
I prefer to use HDL_ANT to calculate focal point´s/gain/etc and it also create templates ready to print for any dish size...use Corel Draw to read the template files that HDL_ANT generate (it create *.PS files, corel draw read those files 100% and you can test it for 15/30days)
Yes, I use HDL_ANT also. Thank you for the newer version which I did not have before.
