- Apr 18, 2004
- Age
- 53
- Tel Aviv, Israel
Canal + / Canalsat gives details of its "HD Everything"
J-30 of its transition to all HD Canal + organized a morning of demonstrations and explanations in his Paris office to explain what will change and what customers can expect !!! On 1 July 2015 ie in exactly one month the Canalsat bouquet will be fully broadcast in high definition !!! 80 channels will be immediately available in native HD !!!! !!! !! but at the same time Canal + announced that its bouquet will not broadcast in 1080p sac plastique !!! The chains that will not be able to provide high-definition images will be broadcast in HD by the technique of "upscaling" !! This will happen in a certain amount of channels that can not provide effective July 1 HD source !!!! For example the chains FRANCE 3 will be made available in native HD Canalsat that as of the end of 2015 !! 15 other channels provide HD native sources between late 2015 and early of 2016 !!! On the audio side all channels will be broadcast in Dolby Digital 2 !!0 and 23 channels will benefit immediately from Dolby Digital 5 !!!!1 !!!! Ultimately the goal of CANAL + is that each channel has a full HD treatment from start to finish !!!! Canalsat channels broadcast 10 maximum for every 50 Mbps an average of 5 Mbps per channel !!!! However this value may change depending on the programs encoding adapting in real time to the image !!! Thus Canal + will provide a smoother image during a ping pong match through a program type recognition algorithm !!! During demonstrations it was stressed the importance of having a good image source !! Indeed while the signal of the Eurosport channel is usually very good at its source the images broadcast during the demonstration were of poor quality fault capture an SD broadcast at that time by the channel !!!! Under these conditions Canal + can not do miracles !!! !!! !! Canal + has also stressed that the transition to all HD including the adoption of the DVB-S2 will improve the reception quality over a million household subscribers who encounter problems in bad weather !!
