Chris
did you tuned up properly your gibi 1.5
can you please give me a digital angle meter reading when you place It on a back support profile and point dish to 28.2
Chris
thank you for reply
but I like to have a practical value of angle, when you place digital angle meter back to back with back feed suport profile of gibi 1.5 - somewhere around conjuction with lower lnb support arm
The 1.2 has a back panel like you have discussed, the 1.5 hasn't. So can you please post a photo of where you want the reading?you are great
appreciate very much
thank you very much
where did you place digital angle meter - Is It on dish
can you measure again but placed at the rectangular back profile at the lower back of the dish around junction with lower lnb support arm
but please only when you got time
cheers
Much better now. Only, instead of holding protractor on the edge of the antenna you better put some straigth plank from top to the bottom of the antenna and then attach protractor to this plank. So, if antenna has 21,5* offset angle and it is pointed to satellite which has elevation 24,9*, than leaning of the face of the dish should be, as you rightly pointed earlier 3,6*. And if you measured leaning 3,1* than you have 0,5* difference and that might automatically mean that LNB's Phase center is not co-located with Focal point of the dish. Another causes of the problem could be that antenna maybe has different offset angle or you have measured leaning angle not precisely or antenna is warped, or protractor is not properly calibrated.... Which option do you prefer?This is the best I can do at the moment. Will try and measure it properly later on.
Not done anything like that yet, not had a real chance.Not good. Did you make string test of your antenna?
How do you do the string test? Please.That, actually, should be first thing that should be done before installing, tuning, testing and making conclusions about performance.
Couple of pictures should be enough. There should not be any gap between strings. Even 1mm is not good.How do you do the string test?
Thank you for that. :-) I will have to pick up some string in the next day or so.Couple of pictures should be enough. There should not be any gap between strings. Even 1mm is not good.
Simple thread or fishing line would also work. Make sure strings are touching edges of the working area of the dish not physical edges of the dish.I will have to pick up some string
