Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
DiSEqc problem
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="2J4EZ" data-source="post: 259080" data-attributes="member: 177124"><p>Did that was on channel 561 qvc germany on astra then i changed to settings in the menu to active antenna 1 is hotbird</p><p>qvc should of gone and the hotbird channels should of come in right??</p><p>but ive still got qvc germany if i push the ? button on the remote it says</p><p></p><p>561 qvc germany </p><p>HOTBIRD FTA German</p><p>12551 MHZ(V) SR 2200 5/6</p><p>Clear</p><p></p><p>is there any way i can get a ofset bracket for my dish all the one ive seen are for the triax dishies the LNB arm on my dish is round not square</p><p></p><p>thanks for your replys</p></blockquote><p></p>
[QUOTE="2J4EZ, post: 259080, member: 177124"] Did that was on channel 561 qvc germany on astra then i changed to settings in the menu to active antenna 1 is hotbird qvc should of gone and the hotbird channels should of come in right?? but ive still got qvc germany if i push the ? button on the remote it says 561 qvc germany HOTBIRD FTA German 12551 MHZ(V) SR 2200 5/6 Clear is there any way i can get a ofset bracket for my dish all the one ive seen are for the triax dishies the LNB arm on my dish is round not square thanks for your replys [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
DiSEqc problem
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
