tflpunk
- Apr 25, 2006
- Age
- 43
- Sky+
- Surrey
Thanks to all your replies
I've worked out what the issue is. Basically, the cccam wasn't listening on any ports at all, which meant it wasn't showing up as open through the likes of Shields Up and/or canyouseeme. org
And I've always wondered why I couldn't access Webinfo in cccam, and that's again because it wasn't listening.
What I've just described is what happens when I run cccam/newcs together. I then discovered that all my ports open and I can access Webinfo if I just run cccam on it's own i.e. they are listening on the ports.
Therefore, my cccam/newcs config is out of sync/corrupt, as something I'm doing in the newcs.cfg is causes the cccam not to listen on the specified ports.
Now I just need to work out what Iv'e done wrong, because I can cccam&newcs working to use my local 'white' card to to open the channels, I just can't get cccam to act as a server when it does.
Unfortunately/Fortunately (depending on how you look at it) I've got a Mac, so I'm unable to run the config B16MC has kindly developed. Which is a shame because all forum questions and help guides point to that.
Thanks again
Dan
Thanks again
Dan
