bin20 said:
i have just installed the hydra anghared but when i try to to download keys or last cpanel it takes along time saying please waite ....downloading marys keys bundel so what will i do?
Best do do then is this:
Do a flash erase so that the image is "clean"
Make sure your network settings are ok.
Load up some channels and get a channel. Select with the blue button "Common interface" and save this. (I am not 100% sure it is needed, but I have a feeling that if you are on a cam that you are trying to change it causes problems)
Download the latest control panel, then reboot,
Download the cams that you want such as newcamd 5.25, reboot again and then go to h**p://yowie.caliph.net.au/hydra/keys/mary.tar.gz
Download the files, unpack them and then FTP them, to the correct place (you will know where by the name of the directories they are in)
I would change all of the files you loaded to CHmod 755
I just did this some while ago and it works ok.
If you still encounter problems then maybe your network settings are not ok.
I have experienced problems with the keys download myself, so that's why I prefer to FTP the files one by one, and then check if the file size is the same.
After that you might need to reboot and then choose newcamd.
