Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Linux Based Receivers
Dreambox Support Forum
Dreambox Satellite Receiver | Tutorials | Software
Dreambox 800
fitting a fan
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="tomthebomb1968" data-source="post: 586986" data-attributes="member: 280905"><p>Hi mate, no it only erases if you choose to upgrade. If you just want a look at the info choose that option then when your finished just close the browser and then reboot the box. Boots as usual</p></blockquote><p></p>
[QUOTE="tomthebomb1968, post: 586986, member: 280905"] Hi mate, no it only erases if you choose to upgrade. If you just want a look at the info choose that option then when your finished just close the browser and then reboot the box. Boots as usual [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
Dreambox 800
fitting a fan
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
