Fox gone. please help!
My key is updated, but still I can't see Fox, Fox Life and cartoon network. Do you think that I have to rescan for channels? pls help
Hi ballack16,
where did you get your updated keys from? A few sites are displaying incorrect keys, try here and compare the keys.
_http://www.turkeyforum.com/satforum/showthread.php?t=2915
Best wishes
Mickha
can anyone help please???
a few weeks ago i bought a dragoncam and loader to try to get more spanish channels.I was very pleased to get several until a few days later they disappeared.
I was advised they they had gone from s*ca to n*gra, ive tried manually imputting codes but to no avail. Im not bothered about takkies, but I would like the cinemania cosmo channels etc-por favor
Hi gazza767,
D+, on Astra 19E, changed encryption and these channels are no longer available, unless you subscribe, at present you are best viewing Hotbird (TPS, S*y, SRG) 13E, or Cabo 30W.
Best wishes
Mickha
hey Mickha .. yes that's my updated key. What could be wrong? even national geographic is gone... but i stil get MTVs, discovery, etc
Hi ballack16,
I experienced this problem with Jimmy, I had to delete it and do a rescan of that frequency, Jimmy came back along with some newly added channels. Please post back with the results.
Best wishes
Mickha
Hi Mickha, I didn't know that Jimmy is working. I wasn't able to see it for quite a long time. However i'll try a rescan and i'll let u know about the outcome. Thanks for the help.
Mickha said:
Hi gazza767,
Best wishes
Mickha
thanks mickha
my next question is how do i subscribe?
I dont know which card I need and if I can purchase in the uk.
do you know roughly how much these cost?
sorry to be so persistant but Im desperate.
gracias
Hi gazza767,
unofficial subscriptions are expensive, I have read figures between £600 - £800, and even higher. If you do an internet search you might find one cheaper, or if you know someone, in Spain, who can get you a legitimate subscription. You might like to view this web site, and links:
_http://www.ultimatetvguide.com/subsonline.htm
_http://www.digicams-uk.com/prod349.htm
Best wishes
Mickha
Mickha said:
Hi gazza767,
Best wishes
Mickha
hi mickha,
thanks again
you were right £650 for a basic card-a bit extortionate in my opinion.
i shall try spanish websites.
hi ballack16
I dont know if youve got fox/cartoon network back yet but we have fox on sk*italia. 12732 mhz h sr 27500 3/4 and ctn net t*s 11778mhz v sr27500 3/4.
you just need to change the language.
Hi gazza767, Yes i know, my problem is with fox etc of sk* italia.
Mickha was refering to sk* italia right? vbmenu_register("postmenu_216617", true);
Mickha said:
Hi mrminibus,
it is a key change and all you need to do is manually update your 0D key in your Dragon, unfortunately a lot of the sites are currently displaying an incorrect key, if you try here and scroll down to S*y Italia, you will find the correct key.
Best wishes
Mickha
Hi , I have a mr cam and when I go unde edit cas keys I do not see ID 2301 listed, how can I add it, if you could help I would greatly appreciate it, Thanks
gazza767 said:
hi ballack16
Hi How do I ad ID 2301 to my edit case key menu on hispasat so that I can watch fox, Thanks if you can help
Hi spikeman,
We were discussing S*y Italia ID:0070 on hotbird
not Hispasat 30W, Cabo.
is your Cam a Matrix reloaded or Revolution? You can find the latest Cam files at sat-key.org
Best wishes
Mickha
Mickha said:
Hi spikeman,
Best wishes
Mickha
Hi, and thank you so much for the response, my cam is a Matrix reloaded, and sorry for the mix up I will look at 0070 and update the keys and see if that works, again thanks
Hi spikeman,
for the other Cartoon Network/TCM channel, on Hotbird, you will have to update your Cyfra+ keys, this channel has not updated their encryption and so is still available on the Dragon.
10949 V 27500
Best wishes
Mickha
hi spikeman,also if you can get hispasat,
some new channels have just appeared
including fox,fox life.3 discovery channels
most in english.
these are on the cabo package.
Thanks Jako,
I appreciate your response, by the way today is 17 May and I looked for the key update for cabo tv but could not find them any news on the new keys. agian many thanks for taking the time.
