Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
HELP!! - Losing channels and BER Rates going up!
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="blueuk808" data-source="post: 545639" data-attributes="member: 283759"><p>Thanks Bigfish!</p><p></p><p>I had an idea that might be the case. I having odd isues with the box crashing occasionally and the network side of things hanging as well.</p><p></p><p>I might get a professional satellite installer out to check the dish as I am concerned over the bracket. In the long run it won't do any harm I guess. If that's the case then it's a new dreambox I guess. The problem with the bracket is that the wall of the house isn't perpendicular, it's on a slight slant where settlement has occured over the years. to compensate I propped the bottom of the bracket out with some coins so that the arm of the bracket was as horizontal as I could get it with a spirit level. I checked it today and while the arm was horizontal, the vertical post seemed out, so I adjusted it, but it doesn't seem to have made that much difference. I might give it one more go and see what I can do.</p><p></p><p>The only other thing I could do to test is to plug the cable into my sky box and see what sky picks up - only concern is then I mess up my sky box!</p></blockquote><p></p>
[QUOTE="blueuk808, post: 545639, member: 283759"] Thanks Bigfish! I had an idea that might be the case. I having odd isues with the box crashing occasionally and the network side of things hanging as well. I might get a professional satellite installer out to check the dish as I am concerned over the bracket. In the long run it won't do any harm I guess. If that's the case then it's a new dreambox I guess. The problem with the bracket is that the wall of the house isn't perpendicular, it's on a slight slant where settlement has occured over the years. to compensate I propped the bottom of the bracket out with some coins so that the arm of the bracket was as horizontal as I could get it with a spirit level. I checked it today and while the arm was horizontal, the vertical post seemed out, so I adjusted it, but it doesn't seem to have made that much difference. I might give it one more go and see what I can do. The only other thing I could do to test is to plug the cable into my sky box and see what sky picks up - only concern is then I mess up my sky box! [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
