Robbo
Retired Mod
- TM6800HD, TM1000, TM600 Linux,TM2200 motor, Channel Master 1.2m motorised, TD110 dish Meter=Satlook Micro+G2 NIT
- Gravesend,Kent,UK
simonglovers said:so you reckon i should ignore the handbook stick it on 50.Adjust the elevation of my dish accordingly and then try and track my arc???
I get everything from 28.2E - 30W. i get some transponders on 42E but cant find 36 or 39 E.
Yes put it on 50 ( or whatever your latitude is). The motor scale is marked LATITUDE, so you just set to your latitude. With it like you have it, your arc will come down too much at the sides.
