Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Sky Digital BSkyB, Freesat & Saorsat support forum
Freesat digital TV support forum
Help with Bush SD receiver
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="atomheart" data-source="post: 577271" data-attributes="member: 308523"><p>Never did. I have the box set up in my bedroom and don't really watch TV that often in there, so still haven't got a solution for it.</p><p></p><p>It seems when the box is initially turned on, most channels work fine, then after a few minutes they slowly stop working, and still nothing updates.</p><p></p><p>If I turn the box on and continue to watch just one channel, the programme will play fine indefinately until I try to change channel and change back. The signal suddenly becomes lost.</p><p></p><p>Seems like an issue with the actual STB more than anything</p></blockquote><p></p>
[QUOTE="atomheart, post: 577271, member: 308523"] Never did. I have the box set up in my bedroom and don't really watch TV that often in there, so still haven't got a solution for it. It seems when the box is initially turned on, most channels work fine, then after a few minutes they slowly stop working, and still nothing updates. If I turn the box on and continue to watch just one channel, the programme will play fine indefinately until I try to change channel and change back. The signal suddenly becomes lost. Seems like an issue with the actual STB more than anything [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
