Hey Mate,prwoolfall said:Sorry I don't live on forums.
I have a dreambox 7000s and several 500's
Again I will repeat you do not need any softcam but SCAM. You do not need a config file. It works on both card readers.
Obviously I do not know your setup but would suggest a clean install of the latest Gemini and download the latest offering of SCAM.
You could try removing your CI reader and trying yet again with your present set up.
Thanks for the info.... I have installed the latest Gemini 4.4.0 and downloaded SCAM from the blue panel, Gemini addons... it didn't work...
I have spent days searching the web to try and find a solution, but not getting very far... Can you confirm you are using Gemini 4.4.0 also? I assume you downloaded your scam from the same source I did? If so, can you suggest where I am going wrong? What version of scam are you using? Perhaps I downloaded an old/incompatible version?
I have removed the CAM from the CI slot, so there is no interference from that source.
Any further help is so very much appreciated. Thanks!
