Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Sky Digital BSkyB, Freesat & Saorsat support forum
Freesat digital TV support forum
Humax FoxSat HDR misbehaving when tuning Freesat
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="archive10" data-source="post: 1054463"><p>See the other thread for discussion.</p><p></p><p>No, I believe it's just he initial network tuning (and possibly software updates) which require the "Freesat signal" (it's really the network information which is there). The EPG should also broadcast on other transponders to support the EPG on a single-tuner box working on other frequencies (eg. tuned to BBC1), but at a much lower bitrate than the homing transponder.</p><p>So, without having analysed the transport streams of Freesat, I think you might be able to make it work by doing the initial tuning at someone else's antenna, then move it to one wher 11426H does not come in.</p><p>But I would recommend realigning the original dish to catch 11426H at Astra 2E if at all possible.</p></blockquote><p></p>
[QUOTE="archive10, post: 1054463"] See the other thread for discussion. No, I believe it's just he initial network tuning (and possibly software updates) which require the "Freesat signal" (it's really the network information which is there). The EPG should also broadcast on other transponders to support the EPG on a single-tuner box working on other frequencies (eg. tuned to BBC1), but at a much lower bitrate than the homing transponder. So, without having analysed the transport streams of Freesat, I think you might be able to make it work by doing the initial tuning at someone else's antenna, then move it to one wher 11426H does not come in. But I would recommend realigning the original dish to catch 11426H at Astra 2E if at all possible. [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
