@SEOShamsher : I am an advocate for aiming at the deepest point of a dish, which is indeed below the center.
For this dish: deepest point is 1048 mm away from top of dish (and 912 mm from bottom of dish).
Others do aim at an even lower point ("G-spot") of an offset dish, which lies on the bisector line: bisecting the lines from focal point to top and bottom the dish.
That would give the least spillover loss, but it would also miss the higher signal density of the higher parts of the dish. So aiming at the deepest point would be a good compromise for that.
But you can try for yourself, as
@RimaNTSS suggested: Aim at the G-spot on the picture by RimaNTSS, or at the deepest point that I calculated, or anywhere inbetween....
P.S. I am not an advocate for the method of satsig.net, from which you posted the picture. I'm an advocate of taking measures of the dish itself, and do sound parabolic calculations on those measures.
Greetz,
A33
