brewby said:
Hi bypassall, It would be nice if you would share your secrets with us 8005 users.
Get the "Downloadprogramm für alle Interstar und BigSAT Premium Modelle.zip.zip" file from the golden-interstar.com site's support page, and extract the "STBDownload-Multi1.8.exe" file to somewhere on your hard drive.
Attach a null modem cable between the computer and the receiver (preferably with the box turned off, at the moment), then run the program.
A window will pop up, with some settings for you to play with
First of all, go to Option and put a tick next to Keep Channel List - THIS IS IMPORTANT if you don't want to have to retune everything!
From the first box, choose the COM (serial) port, you connected the cable to (usually COM1, unless you are using that one for a dial-up modem).
The second box controls the transfer speed and you may need to choose something slower than 115200 if you get checksum errors during transfer.
The third box is the part of the software you want to transfer - set this to KeyData
The fourth box should be set to Upload
Click Connect and then turn on the receiver...
The progress bar will fill up as the computer gets the file and you should now have something called Key(yyyy mm dd).dat in the folder that you ran the program from.
If you need to send the keys back to the receiver, set everything up as before (cables attached, box off, run program, Options - Keep Channel List, choose COM and speed)...
The fourth box should be set to Download this time
You can drag the Key(yyyy mm dd).dat file to the program window, or click File - Load and browse to it. The third box should automatically change to KeyData but double-check to be sure.
Now click Connect and turn the receiver on again.
As before, the progress bar will fill as the box gets the file and near/at the end, the words Flash Write should appear as the box updates. Don't do anything to the program until your receiver has successfully turned back on, because stopping the write early could possibly mess things up
If you ever get four dashes on the front of the receiver, instead of a channel number after an update, it is probably because you forgot to set Keep Channel List and you'll need to retune everything - ALWAYS REMEMBER THE CORRECT SETTING (I've been there, trust me
It is a good idea to make a backup of your channel lists for if this happens - just do the same as with the KeyData but this time, set the third box to Data Only
This file is bigger and (with my setup, anyway) is more prone to checksum errors during transfer to the computer - patience is needed
Hopefully, you'll never need to use this backup and if you ever have trouble with a firmware revision ("version mismatch"), it is possible that the box won't accept it anyway :mad:
"But hey, let's make sure it doesn't come to that"
