Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Miscellaneous Sections
Tech Head - The Technology Section
The Work Bench and Soldering Station
Manhattan Rx with a dead Power Supply
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="FTAaddict" data-source="post: 486669" data-attributes="member: 279756"><p>Thanks Llew for the great help, looks like I'll have to dig deeper. I did document the readings with the PS connected to the mainboard but neglected to post them, they are still fairly consistant in the low range.</p><p></p><p> Hi HB13DISH, I thank you too, unfortunately I gave my other receiver to my friend who is using it now, I'd hate to deprive him of TV <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite9" alt=":eek:" title="Eek! :eek:" loading="lazy" data-shortname=":eek:" /> but the good thing is that I have documented the readings which should help in the diagnosis.</p><p></p><p>These receivers were purchased here in the US and have the 110vac cord, I did notice that the PCB has another plug near the 110vac plug that might be for UK use.</p><p></p><p>Anyway, as you said it will take some time and patience, I have them both. I'll let you know how it goes, it might take me a while <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite53" alt=":confused" title="Confused :confused" loading="lazy" data-shortname=":confused" />. Thanks to you all for such great support. I'll be back <img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png" class="smilie" loading="lazy" alt=":)" title="Smile :)" data-shortname=":)" /> Until then, Cheers!</p></blockquote><p></p>
[QUOTE="FTAaddict, post: 486669, member: 279756"] Thanks Llew for the great help, looks like I'll have to dig deeper. I did document the readings with the PS connected to the mainboard but neglected to post them, they are still fairly consistant in the low range. Hi HB13DISH, I thank you too, unfortunately I gave my other receiver to my friend who is using it now, I'd hate to deprive him of TV :eek: but the good thing is that I have documented the readings which should help in the diagnosis. These receivers were purchased here in the US and have the 110vac cord, I did notice that the PCB has another plug near the 110vac plug that might be for UK use. Anyway, as you said it will take some time and patience, I have them both. I'll let you know how it goes, it might take me a while :confused:. Thanks to you all for such great support. I'll be back :) Until then, Cheers! [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
