Measat3 91.5E astro running NDS
verywiseguy
Dreambox 7020
Malaysia
Do you think using a Dragon CAM helps in our situation...? O-no My 7020 has a CI slot. I'm really puzzled why a valid card doesn't work with cccam 2.0.9. :-doh!
peter_ng
DM500S & DM600PVR-S
P.J, Sel, Malaysia
there just upgrade the security...no cam can work at the moment...!
kel888888
1.5m prime focus dish for chinasat6b
malaysia
hi mr expert, any hope to make it work with ast**??
offside
DM7000
DM500
Indonesia
thx btw
but, how long it will be happen?
thx anyway
gaul
dm500s
bsb
any solusin for this problem?
Im sure when a solution comes along someone will post the information for us. In the meantime theres no point asking the same question over and over again.
gaul
dm500s
bsb
some people say nds3 woking on newcs1.5, have you try it?
nghockmeng
command
johor
No Cam Can Work With Nds.
Rubbish. many cams (both softcams and hardware) can read NDS cards
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
sure,some cams will work,but the auto update funtkion will not work,you have to leave your card every 3 weeks,in the orginal receiver,then back to the cam!
shsoya
cccccccccccccccccccccc
malaysia
Turok said:
Hello!
what cam you use?
gaul
dm500s
bsb
Turok said:
Hello!
shsoya said:
what cam you use?
i use ndscam v0007 not working
No DCW Present
image removed as it contains hex strings - admin
ASTRO Satellite Pay TV
Malaysia
Hi any updates? im a complete noob. will dragon cam or t-rex work for astro with my gold smart card? i dont care bout having to leave it in the original receiver now n then.
verywiseguy
Dreambox 7020
Malaysia
:-worship I'm interested to know the update/progress also. My 7020 has been collecting dust at home... :-rofl2
~VWG
in KL
tomlase
6 ft dish
Indonesia
some say it's possible to decrypt NDS 3 by using CCcam 2.1.0.... does anyone have a chance to try it? :-worship
offside
DM7000
DM500
Indonesia
i'm sorry
its not working with my dm... U-zzz
Malaysia
im trying to get my dragon cam with predator 3.69 to work. The cam detects my gold smart card correctly but the problem is that Astro Box serial numbers are S followed by a 13 digit number. Dragon Cam only allows for 10 digits in the NDS Serial setting :S any ideas?
Malaysia
Also using my astro box the signal strength is about 58% whereas using my humax configured corerctly its only 24% so i cant even find any channels. Is it possible that the humax is under powering the LNB? There are 2 options for LNB power - standard and high. Im scared ill blow my LNB if i set it to high...
Malaysia
Ok. I found out that my LNB is the old type (1st gen astro) whoch is not universal. Setting the local oscillator to the right frequency gave the correct signal reading, and I can see all the channels, but obviously when I try to watch them they are encrypted. Any help with the serial number thing?
zdan
Dreambox 7000S, DM800HD, motorized 1.8M Dish. Twin c/Ku Yuri LNBs.
Malaysia
Astro NDS card married with it own provider STB and therefore currently will not work with any stb's. I tried with latest CCcam but still same. I believe there's are solution, but we need an expert advice to share the knowledge. Thank.
