_http://www.ftemaximal.com/espanol/productos2.php?idt=2&idss=16&idp=722&num=1&idserie=17ralphmagno said:hello to all,
does anyone have any info on the fte clamp 0701116?
i went to their site and could not find it.
thanks
ralph
How many LNBs are there altogether? I make it 16 (45E, 42E, 39E, 36E, 28E, 26E, 23E, 19E, 16E, 13E, 9E, 1W, 5W, 30W and the motorised). Is that right?sonnetpete said:Now I need to plan out the switching
Huevos said:How many LNBs are there altogether? I make it 16 (45E, 42E, 39E, 36E, 28E, 26E, 23E, 19E, 16E, 13E, 9E, 1W, 5W, 30W and the motorised). Is that right?
Huevos said:And what switches did you buy?
Sounds good to me. If you are ever going to go beyond 16 you would need another Spaun. You could have gone for 5 Spaun SUR 420 but at 50€ a piece that works out a few bob.sonnetpete said:I have this feeling I've got this wrong.......Four Vantage VT-DS4/1HQ feeding a Spaun SUR 420 WSG
Huevos said:Sounds good to me. If you are ever going to go beyond 16 you would need another Spaun. You could have gone for 5 Spaun SUR 420 but at 50€ a piece that works out a few bob.
Huevos said:Personally I'd make a spreadsheet so you can keep track of your LNBs
Huevos said:....and how to address them.
That bar you have on the Triax looks very long ,I've normally only seen bars that support a 20 degree span.sonnetpete said:Luckily in the bag with the Triax bar I got two extra LNB holders (so seven instead of five). It's just as well as one of them has developed a crack while fitting an LNB.
Thanks Petesonnetpete said:As far as I'm aware it's a Triax made bar specifically for 5 LNB's. I bought it from Amazon France,
_http://www.amazon.fr/gp/product/B004Y62GTE/ref=oss_product
Don't forget, I've stuck an extra LNB on one end which may make it look a little longer. If it has a fault it's the lack of elevation adjustment for sats at either end. I.E. 42°E will be fine but 16°E will be too low or the opposite will apply. I've modified the bar holder to get more of a slant on the bar but I have seen similar Triax bars where they've been attacked with a hacksaw and given more of a bend. Not that I'll be doing that!!
Fano said:.......Seems to be due to the target area for design being Germany and central europe where the bar doesnt need to tilt as much.
