Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
Motor suitable for a triax td110
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="satelliteman" data-source="post: 532117" data-attributes="member: 255812"><p>Two options: </p><p></p><p>H-H mount 36V motor </p><p>or Polar mount with actuator jack for larger dishes.</p><p></p><p>If your receivers doesn't support 36V positioning then you will require a V box.</p><p></p><p>The setting up principle is the same but more involved although personally not done a actuator/polar</p><p></p><p>SM <img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png" class="smilie" loading="lazy" alt=":)" title="Smile :)" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="satelliteman, post: 532117, member: 255812"] Two options: H-H mount 36V motor or Polar mount with actuator jack for larger dishes. If your receivers doesn't support 36V positioning then you will require a V box. The setting up principle is the same but more involved although personally not done a actuator/polar SM :) [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
