Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
Multi LNB Triax 1.1 on a motor
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Robbo" data-source="post: 487521" data-attributes="member: 256551"><p>You could use the motor in combination with the multi LNB bracket. But bear in mind that due to the design of the bracket, you may not be able to get one of the LNBs at the dish focus, so will have a very slighly weaker signal, than you would with just a single LNB.</p><p></p><p>To wire up the motor (if it is a Diseqc) just wire to the motor first and then to the switch and then to the 4 LNBs.</p><p></p><p>For a 36V motor, the motor wiring is obviously separate, but your receiver would need to support DiSEqC1.0 to control the switch.</p><p></p><p>Qucker zapping can be performed if you set the LNBs up so that they are pointing to your favourire sats when the dish is at a chosen position.</p><p></p><p>Eg when at 19.2E, you could also get 28E 13E and 10E maybe without the dish having to move.</p><p></p><p>Robbo<img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png" class="smilie" loading="lazy" alt=":)" title="Smile :)" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="Robbo, post: 487521, member: 256551"] You could use the motor in combination with the multi LNB bracket. But bear in mind that due to the design of the bracket, you may not be able to get one of the LNBs at the dish focus, so will have a very slighly weaker signal, than you would with just a single LNB. To wire up the motor (if it is a Diseqc) just wire to the motor first and then to the switch and then to the 4 LNBs. For a 36V motor, the motor wiring is obviously separate, but your receiver would need to support DiSEqC1.0 to control the switch. Qucker zapping can be performed if you set the LNBs up so that they are pointing to your favourire sats when the dish is at a chosen position. Eg when at 19.2E, you could also get 28E 13E and 10E maybe without the dish having to move. Robbo:) [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
