Fano
- T90 Dish and Smart 60cm Dish @28.2E
Receivers:Dm800s,Dm600s,Dm500s,
Ferguson Ariva 120,Opticum x403p,Tm 500.
Satlink 6906 meter
- Ireland
sonnetpete said:I have one of these with a 1.2M dish attached and can testify to it's robustness! It's well made and engineered with heavier duty brackets than other motors. It didn't budge when there were strong winds here the other week. I think it would handle a 1M Gibi easily.
Thanks for that info sonnetpete ,reassuring to know.
Looks good allright Hakon.Maby a bracket like these had been a better choise for your setup. I have never used the T and K bracket but i see that they are offen used in UK , the one i show in pics. are more used in sweden
I like the idea of the bracket having minimum contact with the wall .I had to remove the dash off my wall to put the T brackets on ,a messy job to get the plate flush with the wall.
I'd need Spider brackets with an offset of at least 50cm to allow the dish to turn enough Westwards without hitting the wall.
Because of their design they may stop the dish turning enough westwards ,edge of dish may hit the support arm.
Dont get me wrong,the T brackets I currently have up are rock solid ,they will easily support the dish and me hanging off it if necessary
I may change to the hh390 soon as I think my Superjack is faulty .It wont move Eastwards anymore .
